Solved Single Sign-on
12 years 1 month ago #154602 by chasiv
Single Sign-on was created by chasiv
I did a search of the forum and could not find an answer to this so I figured I'd ask the community.
I noticed in this forum that is has its own login. Is it possible to have it use only the Joomla login so when you log into the Joomla portion of the site you are already logged into the forum? I have a few other sites with older versions of Joomla that are using the CB Connector to accomplish this with a phpBB forum. I also know that I can purchase Alterbrains to accomplish this on my the new site I'm working on. But I was looking for something that is free that can connect Joomla and a forum so the user only needs to log in once and so all the Profile information is once in once location.
If you could please let me know if this is possible with Kunera it would be appreciated. I would want to disable individual forum registration and logins.
Thanks for any responses and help with this.
12 years 1 month ago #154650 by sozzled
Replied by sozzled on topic Single Sign-on
chasiv wrote: If you could please let me know if this is possible with Kunera it would be appreciated. I would want to disable individual forum registration and logins.
See Disable (or hide) the login form in the Wiki.
The following user(s) said Thank You: chasiv
12 years 1 month ago #154663 by NickC4555
Replied by NickC4555 on topic Single Sign-on
Kunena natively uses Joomla user accounts and authentication. If you login to Joomla, you are logged in to Kunena.
12 years 2 days ago #155745 by aluna
Replied by aluna on topic Single Sign-on
I'm using version Kunena 3.0.5. Options tab in Kunena Joomla Integration Plugin doesn't show up, thus can't disable Kunena Login form.
Any clue?
12 years 2 days ago #155746 by sozzled
aluna wrote: I'm using version Kunena 3.0.5. Options tab in Kunena Joomla Integration Plugin doesn't show up, thus can't disable Kunena Login form.
G'day, aluna, and welcome to Kunena.
It may assist us to help you if you looked at the helpful information printed at the top of this page:
12 years 2 days ago - 12 years 2 days ago #155747 by aluna
Here it goes...
EDITED:
I found those options in Joomla Plugin Manager, not in Kunena Plugin Manager.
Thanks anyway.
Last edit: 12 years 2 days ago by aluna.
