Solved I delete posts/topics but they still seem to be there ... ?
12 years 3 months ago - 12 years 3 months ago #153893 by picht
Hi
I have a problem with Kunena.
I have installed a clean Joomla 2.5.18 site and the Kunena 3.0.4. Nothing else !
Then i log into the frontend and create a post in Kunena. After the post is saved i click on the "delete" button. The page reloads, but the post is not shown as deleted. I can click multiple times and nothing happens (except for the reload).
If i then hit some of the other kunena menu items suddenly a lot of "The message was deleted" messages appear. (See attached picture)
How do i fix that ?
htaccess: Exists | PHP environment: Max execution time: 3000 seconds | Max execution memory: 256M | Max file upload: 100M
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Plugins: None
Regards
Picht
Last edit: 12 years 3 months ago by picht.
12 years 3 months ago - 12 years 3 months ago #153895 by sozzled
There are known problems with the Beez20 template. Would you like to try your test again with a different Joomla template for J! 2.5?
I'm not sure what really has caused your problem.
Last edit: 12 years 3 months ago by sozzled.
12 years 3 months ago #153898 by picht
Hi
Same problem with the Atomic template...
/Picht
12 years 3 months ago - 12 years 3 months ago #153900 by sozzled
Here are a couple of suggestions:
(1) Use Kunena Forum » Forum Tools » Recount Statistics in the backend (try the test again)
(2) Enable Global Configuration » Site » SEO Settings » Use URL rewriting = Yes (try the test again)
(3) Reinstall K 3.0.4 - do not uninistall Kunena from your site (use the method shown in the K 3.0 Upgrade Guide ) - - and then try the test again.
12 years 3 months ago - 12 years 3 months ago #153901 by picht
I have tried all 3 options and none of them work... :(
12 years 3 months ago - 12 years 3 months ago #153902 by sozzled
This is an interesting puzzle, isn't it?
picht wrote: I log into the frontend and create a post in Kunena. After the post is saved I click on the "delete" button. The page reloads, but the post is not shown as deleted.
This is where the problem begins. The site administrator should always be able to see deleted topics or deleted posts within topics (unless you permanently delete the posts/topics). The real question is here what do you mean by "the post is not shown as deleted".
picht wrote: I can click multiple times and nothing happens (except for the reload).
This could be a caching issue but I can't be sure.
What are the Joomla global settings for caching?
picht wrote: If i then hit some of the other kunena menu items suddenly a lot of "The message was deleted" messages appear.
Very odd. :unsure:
One other thing you might try is to use Kunena Forum » Forum Tools » Synchronize Users and check all the checkboxes.
