Solved Button images broken after upgrade
12 years 2 months ago #153859 by amagab
All button images are broken after I upgraded. How do I fix?
12 years 2 months ago #153861 by sozzled
G'day, amagab, and welcome to Kunena.
I suggest that you start by reading the article My Joomla site template makes a mess of Kunena ... and that you watch the video vimeo.com/69818669 .
12 years 2 months ago #153862 by amagab
Thanks for the fast response. I've used my Joomla template together with older versions of Kunena without any problems, so I'm not sure why it would break now. Any help is highly appreciated. Here's my report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : yoo_pure | author: YOOtheme | version: 5.5.14 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Plugins: None
12 years 2 months ago #153863 by amagab
Actually, to correct myself, it doesn't seem to be the images but the language on the images. My buttons look like this:
Examples in front end:
COM_KUNENA_BUTTON_TOPIC_REPLY
COM_KUNENA_BUTTON_MESSAGE_REPLY
Examples in back end:
COM_KUNENA_PLUGIN_MANAGER
COM_KUNENA_SYS_BUTTON_FILTERSUBMIT
...etc...
12 years 2 months ago - 12 years 2 months ago #153864 by sozzled
amagab wrote: I've used my Joomla template together with older versions of Kunena without any problems, so I'm not sure why it would break now.
I have seen similar responses to yours before andI have no other answer except to repeat what we have written in My Joomla site template makes a mess of Kunena ... :
If your Joomla site template is important to you - and Kunena doesn't work with it - you should contact the author of your Joomla site template and explain the problem to them and ask for their help. Any reputable Joomla template developer should provide those kinds of services especially if you purchased a template from them.
It may be quite true that you have used your Joomla site template with older versions of Kunena and not had any problems. I believe you. It is also true that, before updating a live website with new versions of software, the best advice is to test the update first (see Reviewing your Joomla installation )
Unfortunately for you, because you have blacklisted access to your site from my location - I live in Australia - I cannot see what is going on and I have ideas how to help you further if (as I suspect) the problem is caused by some quirky CSS. My advice is to contact your Joomla tempate developer and ask for their advice or, alternatively, consider a different Joomla site template.
Last edit: 12 years 2 months ago by sozzled.
12 years 2 months ago #153865 by sozzled
amagab wrote: Actually, to correct myself, it doesn't seem to be the images but the language on the images. My buttons look like this:
...etc...
This means that the symbolic names are not being translated properly.
This could be the result of a faulty upgrade. Did you use the method described in K 3.0 Upgrade Guide or did you use some other method?
This problem has also been discussed before on this forum (for example, see K 3.0 buttons display constant names ). In many of these cases the simplest solution seems to be to perform the upgrade procedure again using the method described in the documentation Wiki.
