Solved Menu problems after updating from K 3.0.3 to K 3.0.4
12 years 4 months ago #152666 by yayatlavio
Hai.. I'am Newbe in Joomla and Kunena
After update Kunena 3.0.3 to 3.0.4 via auto update.. can not acsess list of forum only Index page.. This is my website Configuration Report
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : design_control | author: Shape5.com | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Third-party components: AlphaUserPoints 1.9.3 | CommunityBuilder 1.9.1 | Jomsocial 3.0.1 | UddeIM 3.2
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1
Please help us
regard
12 years 4 months ago - 12 years 4 months ago #152669 by coder4life
Is there any error that is displayed when trying to access the index page?
You may have integration problems, sometimes after an update from Kunena these pieces of software are not expecting an underlying change and break.
Please disable any extensions not related to Kunena in the Plugin section of the Kunena Configuration Report and any Third-Party Components also in that section.
You may also have a template problem, please change your template to the default Protostar template in Joomla.
Please try these steps above and post the results here so we can determine how to proceed.
Last edit: 12 years 4 months ago by coder4life.
12 years 4 months ago #152672 by sozzled
The problem is that the menu is messed up with fixed, out-of-date references. There is a link on the main menu that goes to the Recent Topics view. I cannot find a link on a menu that references the "index page".
The following user(s) said Thank You: yayatlavio
12 years 4 months ago #152690 by yayatlavio
thanks for replay
I find the problem .. arrangements for multi language. Kunena menu i set to all languages ​​.. now goes well ..
kind regard
Time to create page: 0.261 seconds
