Solved Where are the installed languages??
12 years 4 months ago - 12 years 4 months ago #152262 by mickstermick
I'm looking forward to using Kunena but I've come across a little problem.
I've installed the language pack (several times now) but I can't find it anywhere.
Can someone point me in the right direction? I'm at a total loss and have been looking for hours.
Thanks :dry:
Last edit: 12 years 4 months ago by mickstermick.
12 years 4 months ago #152264 by mickstermick
Here is the config report:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : Liquidity4 | author: MK Web design | version: 4.1.0.5621 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Plugins: None
12 years 4 months ago #152266 by sozzled
mickstermick wrote: I've installed the language pack (several times now) but I can't find it anywhere.
Have you looked on the download page ?
12 years 4 months ago - 12 years 4 months ago #152275 by mickstermick
Hi Sozzled,
Yes I've downloaded the zip from that page and installed it via admin/extension manager.
The problem is, it isn't showing up anywhere in the Joomla 3 installation. So, my question remains the same; Where are the Kunena languages installed to?
I've checked in components/com_kunena/language and the only language is en-GB. I've checked the Joomla admin/extensions/languages and there are only the languages that I've installed seperately. :)
12 years 4 months ago #152344 by sozzled
12 years 4 months ago #152348 by mickstermick
I've sorted it now - thanks. And perhaps I didn't make myself clear. I wanted to know where the languages were installed to. That info isn't very clear to me.
Any way, job done.
