Solved Blank page in backend
12 years 5 months ago #151597 by fionabiddle
Hi
From my joomla administrator page, when I click on anything from the Kunena drop down menu all I get is a completely white page.
It is a while since I needed to change anything but it all used to work fine
thanks for your help
Fiona
12 years 5 months ago - 12 years 5 months ago #151606 by sozzled
Replied by sozzled on topic Blank page in backend
G'day, Fiona, and welcome to Kunena.
I'm not sure if I know where to begin here but, perhaps, let's start with "it all used to work fine"? Somewhere, along the way, something has changed on your site and neither you (nor we) know what that change was. Therefore, if we can begin with a couple of basic pieces of information, maybe we can backtrack from the current situation until we find that point when things changed.
Is it possible for you to produce your Kunena configuration report? I am aware that the "dropdown menu" does not function but I am wondering what happens if you try to enter the URL:
http://<domain-name>/administrator/index.php?option=com_kunena&view=report
If you can directly access the Kunena configuration report, can you post your configuration report here? If you cannot get to your configuration report, can you tell us (a) the URL of your website, (b) what version of Joomla you are using, (c) what Joomla adminstration template you are using, and (d) have you installed any Joomla extensions that may affect your Joomla adminstration site, please?
I still do not know if I can help in resolving this problem for you, but I would like to try.
Last edit: 12 years 5 months ago by sozzled.
12 years 5 months ago #151608 by fionabiddle
Replied by fionabiddle on topic Blank page in backend
Hi
Thank you for your reply!
Doing the link to the report still gave a blank screen.
The url is www.hypno-psychotherapy.net ,. version of joomla is 2.5.16
I dont know what an admin template is... but in template manager it says
Atomic - Default Site Atomic 3
Beez5 - Default Site Beez5 6
Beez2 - Default Site Beez_20 4
Bluestork - Default Administrator Bluestork 2
Hathor - Default Administrator Hathor 5
rt_halcyon - Default ✭ Master
In terms of extensions we have these in module manager:
SobiPro Entries Module :: None :: SobiPro Entries Module None Public All 108
Latest News bottom-a RokTabs All Public All 99
Shop header-f RokEcwid Mini-cart Module All Public All 103
Kunena Menu kunena_menu Menu All Public All 105
Member Login login Login All Public All 16
Breadcrumbs position-2 Breadcrumbs All Public All 17
Main Menu position-7 Menu All Public All 1
Conference 2012 options showcase-a RokFeatureTable Selected only Public All 104
Features showcase-a RokStories Selected only Public All 102
Map - showcase showcase-a SobiPro GeoMap Module Selected only Public All 109
Find a therapist sidebar-c SobiPro GeoMap Module Selected only Public All 107
Chat sidebar-c FCChat Selected only Registered All 115
Latest News sidebar-c RokNewsPager Selected only Public All 100
Who's online?
THESE in plug ins:
Authentication - Joomla authentication joomla Public 401
Authentication - GMail authentication gmail Public 400
Authentication - LDAP authentication ldap Public 402
Captcha - ReCaptcha captcha recaptcha Public 439
Content - Load Modules content loadmodule Public 406
Content - Joomla content joomla Public 435
Content - Smart Search content finder Public 441
Content - Email Cloaking content emailcloak Public 404
Content - RokBox content rokbox Public 10030
Content - Code Highlighter (GeSHi) content geshi Public 405
Content - Pagebreak content pagebreak Public 407
Content - Page Navigation content pagenavigation Public 408
Content - Vote content vote Public 409
Editor - JCE editors jce Public 10053
Editor - CodeMirror editors codemirror Public 410
Editor - None editors none Public 411
Editor - TinyMCE editors tinymce Public 412
Button - Article editors-xtd article Public 413
Button - Image editors-xtd image Public 414
Button - Pagebreak
The only thing that has been done lately is captcha wasnt working so that was updated... could that be it?
12 years 5 months ago - 12 years 5 months ago #151612 by sozzled
Thanks for your reply.
I was able to confirm that you have K 3.0.3 installed on your site but I am at a loss to understand why you are unable to access any of the backend functions that allow you to administer the Kunena component. It seems to suggest that either there's something interfering in the administrator (i.e. backend) side of things as the result of a change you have made there or that, perhaps, the current installation of Kunena may be corrupted in some way.
It may be worthwhile re-installing K 3.0.3. Re-installing is done in the same way as you installed Kunena in the first place (see K 3.0 Installation Guide ). There is no need to uninstall K 3.0.3 before using the same procedure to re-install the component. Re-installing Kunena will not affect your existing configuration settings or any messages already posted on your forum.
I suggest that you attempt to re-install K 3.0.3 using the procedure shown in K 3.0 Installation Guide . Please let us know how you get on.
12 years 5 months ago #151620 by fionabiddle
Hi
I re-installed and it made no difference... any other suggestions?? I am stuck!
best
Fiona
12 years 5 months ago #151621 by 9themestore
Replied by 9themestore on topic Blank page in backend
Hi Fiona,
Can you pm me (via email)? I will try to find the reason of this problem.
Regards,
Time to create page: 0.279 seconds
