Question Installed but not displaying?
12 years 11 months ago - 12 years 11 months ago #151379 by KeithLemon
I'm new to this whole Kunena and Joomla software. I've tried following the wiki as much as possible but completely confused.
I've installed Joomla, I've added Kunena via the extension manager but I can't see Kunena when I go on my website.
How do I set Kunena as the default site? I did read on the wiki that it come with a default theme but I don't see it. What I see is the original Joomla when you install it.
Any help is greatly appreciated.
UPDATE: I found a template named 'Blue Eagle' in the Kunena tempalte manager which says it's installed already but I don't see this being displayed. I checked using the extension template manager and it's not displaying it there.
This theme is already selected as being default, still not displaying.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
Last edit: 12 years 11 months ago by KeithLemon.
The topic has been locked.
12 years 11 months ago #151381 by Jiminimonka
If you are new to Joomla, then you probably have to go to the Menu Manager in the Joomla Administration page and Publish the Kunena Menu. It will be in Main menu section.
I advise you to find some Joomla tutorials on youtube and at Joomla.org if you are new to using Joomla, as it will help you a great deal.
Please read the FAQ.
Only one question per topic.
12 years 11 months ago #151382 by KeithLemon
Jiminimonka wrote: If you are new to Joomla, then you probably have to go to the Menu Manager in the Joomla Administration page and Publish the Kunena Menu. It will be in Main menu section.
It's all published according to the menu manager. If you take a look at www.gmodplayers.com you can see that it is displaying but it's within the default template.
I've tried disabling the default Joomla template but apparently, I cannot do that.
12 years 11 months ago - 12 years 11 months ago #151383 by GoremanX
Kunena is a component of Joomla. It does not replace Joomla. As such, the default Joomla elements do not disappear when using Kunena. The goal is to use Kunena as a forum element within the overall site. So you'd have separate menu items for an articles section, a forum section, and for other stuff (there are countless components for Joomla). If you're looking to run a site that is solely a forum and nothing else, then your best bet would be something along the lines of phpBB. There's no need for a content management system at all for that.
Unfortunately, making the most out of Joomla is beyond the scope of this forum. We only provide help specifically for the component we develop and publish (Kunena). If you need more help learning how to configure Joomla for your uses, I'd recommend starting here:
docs.joomla.org/Portal:Beginners
www.friendlyphotozone.com
Last edit: 12 years 11 months ago by GoremanX.
12 years 11 months ago #151384 by KeithLemon
GoremanX wrote: Kunena is a component of Joomla. It does not replace Joomla. As such, the default Joomla elements do not disappear when using Kunena. The goal is to use Kunena as a forum element within the overall site. So you'd have separate menu items for an articles section, a forum section, and for other stuff (there are countless components for Joomla). If you're looking to run a site that is solely a forum and nothing else, then your best bet would be something along the lines of phpBB. There's no need for a content management system at all for that.
I was peeled to use this when I seen zarpgaming.com/
If you check, you can see they're using Kunena and it looks pretty cool, I wanted to try something like that.
12 years 11 months ago #151387 by originalhandy
Have you got an actual website built or do you just have your Kunena forums in ? You can display Joomla menu's on your Kunenea forum but you need a site etc first with menu's.
Time to create page: 0.155 seconds
