Solved Missing Kunena Menu
12 years 11 months ago - 12 years 11 months ago #151295 by carterx
Missing Kunena Menu was created by carterx
I've move, change or done something that has now removed the Kunena menu from my forum. The menu is still in the back administrator end but can't figure out why it's not showing up on my forum.
I've gone over the template, menu assignments and even have a fresh site installed trying to figureout where I need to make changes to get it back.
This is what my forum looks like right now:
I'm missing this menu as seen here on the Kunena site:
Last edit: 12 years 11 months ago by carterx.
12 years 11 months ago #151296 by Jiminimonka
Replied by Jiminimonka on topic Missing Kunena Menu
Have you used the tools in Kunena Admin, there is an option to rebuild the Kunena menu.
Please read the FAQ.
Only one question per topic.
12 years 11 months ago #151297 by carterx
Replied by carterx on topic Missing Kunena Menu
I tried the "Restore Kunena Menus" but no luck. Still no menu appearing ;(
12 years 11 months ago #151299 by Mortti
Replied by Mortti on topic Missing Kunena Menu
Have you checked this? --> screencast.com/t/kzdJjLj9N
The following user(s) said Thank You: Earthson
12 years 11 months ago #151302 by ManuelVoileux
Replied by ManuelVoileux on topic Missing Kunena Menu
I have had the problem as well. When I installed Kunena, fine, the menu was there. I started playing with the options and bang ! no more Kunena menu. Actually as long as I did not touch template management everything was OK :)
Go to Template management >> I have only one template "Blue eagle"
Open the template, the first option on the left column is "show Kunena menu" and by default the option is set to NO. :huh:
However, as long as you do not open and save the template, the Kunena menu is shown !!!
So open the template, turn this option to YES and save.
It worked for me. Hope this helps
my site is voileux.org , Joomla 3.2, template protostar, Kunena303
Manuel
voileux.org
12 years 11 months ago #151303 by carterx
Mortti wrote: Have you checked this? --> screencast.com/t/kzdJjLj9N
ManuelVoileux wrote: Hello,
Manuel
voileux.org
Thanks but this doesn't work. I think i need to start a fresh site and import the forum users/data separately to get it back..
