Solved Attachments will not load on Forum
12 years 11 months ago - 12 years 11 months ago #151345 by rasty
I started having problems attaching pictures on our Forum. The picture appears as
[attachment:1]P1010063_small.JPG[/attachement]
but we get a "Warning - Copy Failed" and
"Error - Cannot save message. Message Body is Empty"
Any help would be appreciated!
Last edit: 12 years 11 months ago by rasty.
12 years 11 months ago #151346 by rasty
htaccess: Exists | PHP environment: Max execution time: 660 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
12 years 11 months ago #151347 by coder4life
Out of curiosity do you have any text in the message box when saving the attachment.
12 years 11 months ago #151349 by rasty
Does not work either way. I have tried both ways
12 years 11 months ago #151351 by coder4life
You may have a permissions issue. Permissions are set on files and folders that allow you or scripts in Kunena to access certain files or directories.
www.kunena.org/docs/Kunena_3.0.3_Read_Me#Folder_permissions
Please take a look at the folder and files that must be writable for Kunena to work properly.
If you are unsure how to change permissions please contact your hosting provider to help you.
12 years 11 months ago #151352 by rasty
Thanks. I looked and it appears that I have unwritable permissions. Is there any way to fix this from my side?
Time to create page: 0.150 seconds
