Bug Too many URL's breaks the post...
12 years 8 months ago - 12 years 8 months ago #148206
by Tazsta
Too many URL's breaks the post... was created by Tazsta
Hi all, just want to get this problem sorted as its really annoying.
I can post in the forum fine, i can edit posts fine, but soon as i put more then 3 URL's in a single post when i go to submit the post i get this:
Forbidden
You don't have permission to access /index.php/forum on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Everything else works perfect
Site is www.dota2aus.com
Forbidden
Last edit: 12 years 8 months ago by Tazsta.
12 years 8 months ago #148220
Replied by sozzled on topic Too many URL's breaks the post...
The problem is because you are using a 3rd-party Kunena template that may not be compatible with the version of Kunena you are using. Please contact the developer of the Kunena template for their support.
12 years 8 months ago #148240
by Tazsta
Replied by Tazsta on topic Too many URL's breaks the post...
So how do you explain it having the same problem with the default template then?
12 years 8 months ago - 12 years 8 months ago #148242
Are you asking for us to guess, without knowing anything more about your site than its URL, or are you asking for us to analyse properly how you have put your website together? The only information I could obtain, based on the URL
www.dota2aus.com
- I looked at your site 5 minutes ago - is that you are currently using K 3.0.33 with a Kunena template called NTS Kpraxis and a number of other components that are unknown to me.
To fully understand why your website behaves in a way that is different to how other Kunena forums behave (e.g. this one at www.kunena.org , where we can incorporate as many links in our messages without encountering the kinds of problems you are having) requires knowing more about your site. There is information that appears at the top of this page (relating to the configuration report) that may assist us better.
One sure-fire way to confirm that the issue is not, in some way, related to your webhosting provider, is to try the When all else fails, try this approach.
Another possible reason why your forum limits your users' ability to include up to 3 links in their messages, may have to do with some extra security measures you've incorporated somewhere.
Last edit: 12 years 8 months ago by sozzled.
Time to create page: 0.262 seconds
