Solved nl-NL: Time is not good
12 years 8 months ago #148009 by lifeguard
Hey people
when i look on my memberlist, is see this
How can i fix this?
12 years 8 months ago #148014 by sozzled
Replied by sozzled on topic nl-NL: Time is not good
There is a known problem with the Dutch language translation file for K 3.0.1. You should upgrade to K 3.0.2 and install the K 3.0.2 Dutch language translation pack.
See also K 3.0.0: Dutch translation error: Birthdate shows J instead of year
For future reference, next time you ask a question on this forum, please read the forum announcement posted at the top of this page:
Kunena 3.0.2 [K 3.0.2] is now available for download. This version addresses several important issues that were discovered in previous versions, and supersedes all previous releases, of K 3.0.
Members of the community should also read the main article that summarises details about K 3.0.2. You are also reminded that support for K 2.0 will cease on 31 August 2013 and all categories of the forum that relate to this version will be closed from further discussion on that date.
If you are using the forum to discuss your problems then, for your own benefit, it would save us all a lot of time if you would kindly post your configuration report when you ask for help. If you do not post your configuration report we will not ask you for it but you may not receive a solution to your problem, either.
12 years 8 months ago #148036 by lifeguard
Replied by lifeguard on topic nl-NL: Time is not good
I am already use 3.0.2 :)
12 years 8 months ago #148044 by xillibit
Replied by xillibit on topic nl-NL: Time is not good
Cna-you put here please the Kunena report configuration settings ?
12 years 8 months ago - 12 years 8 months ago #148047 by sozzled
lifeguard wrote: I am already use 3.0.2 :)
Did you also install the K 3.0.2 Language Pack files for the Dutch language, too?
Last edit: 12 years 8 months ago by sozzled.
12 years 8 months ago - 12 years 8 months ago #148412 by lifeguard
I did.
Today also, on a new host.
I installed newest version of joomla, kunena and the dutch language.
Everything is fine, and in Dutch. But i have the same error
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 96M | Max file upload: 32M
Joomla default template details : beez5 | author: Angie Radtke | version: 2.5.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Plugins: None
Last edit: 12 years 8 months ago by lifeguard.
Time to create page: 0.307 seconds
