Solved Errors only on kunena page
13 years 2 months ago - 13 years 2 months ago #147967 by Tryweryn
Hi this is my php.ini file
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; Error handling and logging ; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; error_reporting is a bit-field. Or each number up to get desired error ; reporting level ; E_ALL - All errors and warnings ; E_ERROR - fatal run-time errors ; E_WARNING - run-time warnings (non-fatal errors) ; E_PARSE - compile-time parse errors ; E_NOTICE - run-time notices (these are warnings which often result ; from a bug in your code, but it's possible that it was ; intentional (e.g., using an uninitialized variable and ; relying on the fact it's automatically initialized to an ; empty string) ; E_CORE_ERROR - fatal errors that occur during PHP's initial startup ; E_CORE_WARNING - warnings (non-fatal errors) that occur during PHP's ; initial startup ; E_COMPILE_ERROR - fatal compile-time errors ; E_COMPILE_WARNING - compile-time warnings (non-fatal errors) ; E_USER_ERROR - user-generated error message ; E_USER_WARNING - user-generated warning message ; E_USER_NOTICE - user-generated notice message ; ; Examples: ; ; - Show all errors, except for notices ; ;error_reporting = E_ALL & ~E_NOTICE ; ; - Show only errors ; ;error_reporting = E_COMPILE_ERROR|E_ERROR|E_CORE_ERROR ; ; - Show all errors except for notices ; error_reporting = E_ALL & ~E_NOTICE & ~E_DEPRECATED ^ E_STRICT ; Print out errors (as a part of the output). For production web sites, ; you're strongly encouraged to turn this feature off, and use error logging ; instead (see below). Keeping display_errors enabled on a production web site ; may reveal security information to end users, such as file paths on your Web ; server, your database schema or other information. display_errors = off ; Even when display_errors is on, errors that occur during PHP's startup ; sequence are not displayed. It's strongly recommended to keep ; display_startup_errors off, except for when debugging. display_startup_errors = off ; Log errors into a log file (server-specific log, stderr, or error_log (below)) ; As stated above, you're strongly advised to use error logging in place of ; error displaying on production web sites. log_errors = On
I am getting errors from Gtranslate and the author told me to turn strict error reporting of. What do i modify the php file to do this please.
The errors I was getting were
Strict Standards: Non-static method modGTranslateHelper::getParams() should not be called statically in /home/britmo5/public_html/modules/mod_gtranslate/mod_gtranslate.php on line 13 Strict Standards: Only variables should be assigned by reference in /home/britmo5/public_html/modules/mod_gtranslate/tmpl/default.php on line 115 Strict Standards: Only variables should be assigned by reference in /home/britmo5/public_html/modules/mod_gtranslate/tmpl/default.php on line 130 Strict Standards: Only variables should be assigned by reference in /home/britmo5/public_html/modules/mod_gtranslate/tmpl/default.php on line 209
www.britmovie.net/index.php/forum/index
Only seems on the pages with kunena?
System Information
Setting Value
PHP Built On Linux ld128.inmotionhosting.com 2.6.32-358.6.2.el6.bl1.0.1_1.x86_64 #1 SMP Thu May 30 20:45:26 MDT 2013 x86_64
Database Version 5.5.32
Database Collation utf8_general_ci
PHP Version 5.4.19
Web Server Apache/2.2.24 (Unix) mod_ssl/2.2.24 OpenSSL/1.0.0-fips DAV/2 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635
WebServer to PHP Interface cgi-fcgi
Joomla! Version Joomla! 3.1.5 Stable [ Ember ] 01-August-2013 14:00 GMT
Joomla! Platform Version Joomla Platform 12.2.0 Stable [ Neil Armstrong ] 21-September-2012 00:00 GMT
User Agent Mozilla/5.0 (Windows NT 6.2; WOW64; rv:23.0) Gecko/20100101 Firefox/23.0
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Last edit: 13 years 2 months ago by Tryweryn.
13 years 2 months ago #147984 by xillibit
Replied by xillibit on topic Errors only on kunena page
There errors aren't related to Kunena but to gtranslate module, so you can just disable error reporting in your php.ini or in Joomla! configuration panel.
13 years 2 months ago #148013 by Tryweryn
Replied by Tryweryn on topic Errors only on kunena page
The interesting thing is i turned the errors of via php.ini and the only page they now show is the page with the kunena forum.
13 years 2 months ago - 13 years 2 months ago #148016 by sozzled
Replied by sozzled on topic Errors only on kunena page
Perhaps a little off-topic, but may I suggest that you read Why you should not edit your configuration report . :)
Last edit: 13 years 2 months ago by sozzled.
13 years 2 months ago #148017 by Tryweryn
I havent edited it have I?
13 years 2 months ago - 13 years 2 months ago #148018 by sozzled
Well, your "configuration report" looks nothing like the configuration report you would generate if you followed the instructions given in the video tutorial (see below):
vimeo.com/69818669
Time to create page: 0.235 seconds
