Solved K 3.0 successfully installed on J! 2.5.11, but all pages to access component blank
12 years 10 months ago #146315 by janettka
Found.
Link how to diagnose errors in Kunena
www.kunena.org/docs/How_to_diagnose_blank_page_on_kunena
Link on script to collect information about your site where kunena doesn't work (works for Kunena 3.0)
www.kunena.org/docs/K_1.6_Configuration_Report
1. Copy fpa-en.php in root of site
2. Open browser and type: mysite.com/fpa-en.php
My results below:
12 years 10 months ago - 12 years 10 months ago #146317 by sozzled
Let me make this really simple for you:
How to obtain your Kunena configuration report for K 3.0: Read the article K 3.0 Configuration Report or watch the video ( vimeo.com/69818669 ) which explains, step by step, what you have to do
If you cannot obtain the Kunena configuration report from your site then it is because the installation of Kunena on your site was not successful (even if the installation procedure displayed a message otherwise). So, you now have the problem: what to do with an unsuccessful or corrupted installation of computer software? The standard remedy as we all know is (a) to revert (if you can) to the situation you previously had when everything was working properly and (b) to retrace your steps.
We cannot diagnose the problems for you if your website is accessible on a local [LAN-restricted] PC-based server environment. We can guide you, perhaps, but the diagnosis is something you have to do yourself. Please read again what I wrote to you in msg #2 of this topic and, in particular, the links I included in that message.
Diagnosing "blank pages"? Enable Kunena and Joomla debug mode.
Thank you for the trouble you went in getting that "report" you gave us but, really, the Kunena configuration report is all we need. You seem to be using K 3.0.0. I suggest you use K 3.0.1.
Last edit: 12 years 10 months ago by sozzled.
The following user(s) said Thank You: janettka
12 years 10 months ago #146328 by janettka
I have enabled all possible error reporting cases following debug instructions.
I can't install kunena 3.0.1 with the errors on screenshot.
Problems with schema.php file.
12 years 10 months ago #146329 by janettka
Finally I was able to install Kunena 3.0.1 pkg from tmp folder.
But now see another problem: all itmes in Kunena admin panel displayed with programming language names :
Configuration report attached.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : AllRusty-FJT | author: FJT | version: 1.7.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party components: CommunityBuilder 1.9 | UddeIM 3.0
Plugins: None
12 years 10 months ago #146331 by janettka
I have found the problem.
I am using russian language.
I have installed russian translation for kunena and now it displays fine.
Uuuh.
I am happy now. Thank you for assistance. :)
