Merged Code highlighting (GeSHi)
13 years 3 months ago #145935 by 3XPER7
I don't know why GeSHi support was dropped, but I sure hope it will be brought back.
13 years 3 months ago #145938 by xillibit
Replied by xillibit on topic Code highlighting (GeSHi)
The geshi support is still here in Kunena but since Joomla! 3, the plugin from has been removed form Joomla! libraries. You need to find a plugin for joomla 3 to make geshi working
13 years 3 months ago - 13 years 3 months ago #145940 by 3XPER7
Replied by 3XPER7 on topic Code highlighting (GeSHi)
I did not know that. Maybe it's worth mentioning that I'm still using J! 2.5 as I prefer LTS releases, and J! 2.5 still has the GeSHi plugin by default (I am setting up Kunena 3.0 on J! 2.5 as that was possible). Nevertheless, even with the plugin in J! 2.5 code highlighting doesn't show in Kunena. Seems odd.
This is my second Kunena-related blooper I made this week.. I had Code Highlighting disabled in the Kunena config. I should pay more attention :laugh:, feel free to laugh with me ;)
Last edit: 13 years 3 months ago by 3XPER7.
13 years 2 weeks ago - 13 years 2 weeks ago #149408 by Chico Gois
Hello!
I have problem in BBCode CODE(Enable Code Highlighting), does not work with it selected (YES). Not appear the options to select the desired language. Ie, does not work.
I'm using a clean install of Joomla and Kunena
In version 2.0 did not have this problem.
link: mundophpbb.com.br
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 20M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Plugins: None
Atenciosamente,
Chico Gois
Last edit: 13 years 2 weeks ago by sozzled. Reason: Hide the site login details
13 years 2 weeks ago - 13 years 2 weeks ago #149415 by sozzled
*** Topics merged ***
GeSHi code highlighting was removed from J! 3.x. This is why code highlighting does not work by default. See Kunena Features
13 years 2 weeks ago #149501 by Chico Gois
Thanks for answering.
Technical fouls for forums :)
Anyway any suggestions or literature Kunena for implementation?
Atenciosamente,
Chico Gois
