Solved Problems after installing K 3.0.1 ... all fixed!
12 years 11 months ago - 12 years 11 months ago #145789 by Heurazio
hey everyone,
i've installed the new kunena 3.0.1. if i click on a post i can't see it. i only get a "blank" page with nothing on it. i've used k3.0 since release and never had that problem. i've already tried a reinstallation but it did not help.
to my site
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : Carve | author: Pixel Point Creative | version: 1.1 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party components: UddeIM 3.0
Plugins: None
best regards
heurazio
Last edit: 12 years 11 months ago by sozzled. Reason: Remove spoiler around config report.
12 years 11 months ago #145790 by sozzled
Where is the sample topic on your forum? When you first installed K 3.0.1 on your site did it work without making any changes, just like you would have seen if you watched the video in the K 3.0 Installation Guide in the Wiki. Are you sure that you followed the procedure as documented in the Wiki?
12 years 11 months ago #145791 by Heurazio
it didn't worked with the samples. i've deleted them cause i thought they are the problem. i'm pretty sure that i've propper followed the dokumentation.
12 years 11 months ago #145792 by sozzled
Did you watch the video? Yes or no?
12 years 11 months ago - 12 years 11 months ago #145793 by Heurazio
yes i watched it, the only difference i made was that i installed from an archiv (downloaded from the page to backup it for (maybe) later use) not from a link.
as far as i can see all requirements are matched too and i've made a test installation on my local system ... all worked fine.
EDIT: i've solved the problem by completely removing all kunena components for a second time and reinstalling it.
Last edit: 12 years 11 months ago by Heurazio.
