Solved Preview not working, a 404 Not Found error
11 years 8 months ago - 11 years 8 months ago #162666 by bymamo
Hi!
I have a problem with error:
Forbidden
You don't have permission to access /index.php/foro on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
If I send again the hosting cut conexion with my ip.
I checked with other forum (external domain) and have same problem
Hereby attached problem text
Thanks for your help
Last edit: 11 years 8 months ago by bymamo. Reason: actualiced text
11 years 8 months ago #162669 by 810
please add kunena report
11 years 8 months ago #162671 by bymamo
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 750M | Max file upload: 32M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.7 | creationdate: 2015-02-01
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Plugins: None
11 years 8 months ago - 11 years 8 months ago #162673 by sozzled
I recommend that you change the forum integration plugin settings as shown in red below:
Kunena - UddeIM Disabled
Last edit: 11 years 8 months ago by sozzled.
11 years 8 months ago #162674 by rich
Kunena - Gravatar Enabled: Disabled
Why should this be disabled? You don't know what is used on his page.
I've visited your page, but it works all correct. Is this problem only when you are logged in?
11 years 8 months ago - 11 years 8 months ago #162675 by Mortti
Is there any change if you change your htaccess.txt file to .htaccess ( screencast.com/t/yNEsQOnZ46o5 ) and from Global Configuration of J! set "Use URL Rewriting" ( screencast.com/t/JEP0uepH ) ? Clean system and browser cache before and after testing.
Last edit: 11 years 8 months ago by Mortti.
Time to create page: 0.155 seconds
