Question Kunena Forum Categories & Index Display Error: 1054
12 years 5 months ago #155312 by gamingdecoded
I am having trouble with the configuration of the Kunena v. 3.0.5 forum software I am trying to install & configure on my website. I am using the Joomla! v. 3.2.3 CMS software to build my website using the Shape 5 Vertex template.
I can & have installed the Kunena software just fine through my Joomla! admin dashboard Extensions => Extension Manager. I can also get the Kunena homepage to display properly. The issue I'm having is with the Categories I have created for my forum and getting them to display on the frontend. If I click on the Index tab on the frontend, it gives me the error message screen "Error: 1054" - an image of which I have attached to this message. If I try and select to navigate to any of my created categories, I get the same error message display. As far as I can tell, I have created and configured the categories properly and I'm at a loss as to why I am getting this error message. I have also attached a copy of the report configuration for you to look over.
I imagine the problem is going to be fairly obvious and simple, but I'm at a loss at how to fix this. Any assistance you may be able to provide would be very much appreciated.
My website URL is: www.gamingdecoded.com
Thanks again!
The topic has been locked.
12 years 5 months ago #155313 by sozzled
gamingdecoded wrote: I have also attached a copy of the report configuration for you to look over.
I think you may have forgotten it.
12 years 5 months ago - 12 years 5 months ago #155315 by gamingdecoded
I could have sworn I attached both files. [strike]I am attempting to attach it again to this message. I have saved it as a .txt file in Notepad.[/strike][Moderator's comment]Watch the video vimeo.com/69818669 to see how to attach your configuration report. Configuration report appears below
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 100M
Joomla default template details : shape5_vertex | author: Shape5.com | version: 3.0 | creationdate: Unknown
Third-party components: AlphaUserPoints 1.9.6
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
Thanks again.
Last edit: 12 years 5 months ago by sozzled. Reason: Reveal Kunena configuration report in message
12 years 5 months ago - 12 years 5 months ago #155316 by sozzled
I suggest that you do two things:
1) Change the integration plugin settings as shown in red below:
Kunena - AlphaUserPoints Enabled: activity=1 avatar=1 profile=1 activity_points_limit=0
Kunena - UddeIM Disabled
2) Remove the conflicting menu item (id=357) from your site. See Kunena Menu issues in the Wiki for more information.
12 years 5 months ago #155319 by gamingdecoded
I have made the changes suggested, but the problem still persists. Do you have any other suggestions that could be causing the issue?
Thanks again.
12 years 5 months ago #155323 by xillibit
If you look closely the SQL error, the table concerned isn't from Kunena :
Unknown column 'a.name' in 'field list' SQL=SELECT a.name FROM dr4ub_categories AS a WHERE a.id=0
Try to disable all third party modules and plugins and try if it's without them enabled.
Time to create page: 0.302 seconds
