Question Kunena installed and have menu, but it doesn't load
12 years 5 months ago #151015 by peters-af
I have loaded Kunena v3.03 onto a Joomla 3.1.5 installation. It appeared to load fine and I can work on categories, users, etc.
I have published it and added it as a sub-menu under my clients menu item as it will only be for clients. It shows up there, but when I click on it, it attempts to load but eventually I get a "500 Internal Server Error" "Fatal error was detected".
I have checked the system information settings and all seem to be appropriate. On thing I did notice is that the site uses MySQLi instead of MySQL.
Any suggestions would be appreciated.
12 years 5 months ago - 12 years 5 months ago #151017 by sozzled
G'day, peters-af, and welcome to Kunena.
I do not think your problem is caused by the Kunena menu . HTTP 500 Internal Server Errors are almost impossible to diagnose properly without knowing a lot more about
(a) the detailed error message - you can get more information if you enable Joomla debug mode; and
(b) some more information about your Kunena configuration.
I have not tried to create a website using MySQLi for a long time - years, in fact - but this may or may not be the cause of the problem. Enabling Joomla debug mode should give you more information about whether the problem is caused by using MySQLi or MySQL instead.
Without the information I referred to in (b) above - there is a helpful link at the top of this page - it's almost impossible to say what is the cause of your problems.
Last edit: 12 years 5 months ago by sozzled.
12 years 5 months ago #151020 by peters-af
Thanks for the response. Here is the detailed message after turning on debug:
"Fatal Error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 77 bytes) in libraries/joomla/database/driver/mysqli.php on line 538
The error was detected in the Libraries."
Following is the configuration report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : rt_hexeris | author: RocketTheme, LLC | version: 1.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
12 years 5 months ago #151022 by sozzled
You're out of memory. You could try removing other Joomla extensions you're loading on your Kunena forum pages. Also, because the error message indicates something involving MySQLi, perhaps that's the reason why you're having these problems? Maybe do as I do, use MySQL instead and see if it makes a difference.
Time to create page: 0.235 seconds
