This category is for discussing issues with the K 3.0 Blue Eagle template.
Solved Adjust a couple of color settings
11 years 9 months ago - 11 years 9 months ago #160746 by woogerboy21
Alright, how about updating the color backgrounds on the reply windows?
(See attached image)
I can't get the backgrounds to be a simple white.
Very frustrating...
Last edit: 11 years 9 months ago by woogerboy21.
11 years 9 months ago #160759 by 810
try to check inspector or firebug.
11 years 9 months ago #160760 by 810
or try :
backend -kunena - template manager- edit blue eagle - set blend with joomla template to "Yes"
11 years 9 months ago - 11 years 9 months ago #160762 by woogerboy21
The blend with joomla template is set to yes and is what is making the textarea and input area's a dark blue shade :(
I've managed to track down the bbcode hints, message input and file input elements and set the background colors accordingly but am stuck on the subject line and the area behind the barcode top bar that has the spreadsheet and various little strikethroughs and what nots.
Ive tried this like:
#Kunena input.kinput, #subject {
background-color: #FFFFFF !important;
And it doesn't seem to work so I'm thinking im a bit confused on narrowing down the elements in the CSS line. I also noticed today that the quick reply box / subject will need to be modified as well.
11 years 9 months ago - 11 years 9 months ago #160763 by woogerboy21
Figured it out. Inspector was so much easier to use than firebug (IMO).
Thanks for the suggestion.
And thanks to all others that pitched in as well.
Time to create page: 0.238 seconds
