This category is for discussing issues with the K 3.0 Blue Eagle template.
Question K 3.0.4: bordered tables
12 years 6 months ago - 12 years 6 months ago #155864 by findelat
We are running Kunena 3.0.4 and it has integrated BBCode but some commands like creating borders does not run
Here I write the codes and how it appears
[table border=1] [tr][th]A[/th][th]B[/th][th]C[/th][/tr] [tr][td]A1[/td][td]B1[/td][td]C1[/td][/tr] [tr][td]A2[/td][td]B2[/td][td]C2[/td][/tr] [tr][td]A3[/td][td]B3[/td][td]C3[/td][/tr] [tr][td]A4[/td][td]B4[/td][td]C4[/td][/tr] [/table]
This is how it is shown
ABC
A1B1C1
A2B2C2
A3B3C3
A4B4C4
Does anybody know how to create borders or adjust the shape to the content within?
Thank you.
Last edit: 12 years 6 months ago by findelat.
12 years 6 months ago #155866 by 9themestore
Open the template.css file of the default Joomla template and paste the below CSS rule to bottom of file.
#Kunena .kmsgtext > table { border: 1px solid #ddd; /* You can change by an other color code */ } #Kunena .kmsgtext > table th, #Kunena .kmsgtext > table td { border: 1px soid #ddd; padding: 5px 10px; text-align: center; /* Add this property if you want to align text center */ } #Kunena .kmsgtext > table th { background: #f0f0f0; font-weight: bold; }
After save back to front-end and reload your site to view changed.
Hope this helps
The following user(s) said Thank You: findelat
12 years 6 months ago #155869 by findelat
Replied by findelat on topic K 3.0.4: bordered tables
Thank you.
I am not really sure to have understood what to do or if I dare to do it :blush: , but I will try to change the css file to paste your codes.
I didn't know if it was something related with BBCode updates :blink:
12 years 6 months ago #155885 by 9themestore
You will not lost all custome when you upgrade or reinstall Kunena forum. I think, that is a important reason to should add the CSS custom to the Joomla! template.
12 years 6 months ago #155898 by findelat
I guess it would be this file template.css placed on this path: /public_html/administrator/templates/bluestork/css/template.css
But I don't find anything about kunena to edit it and paste the codes you gave me.
There are almost 3200 lines but I don't find it
I have also tried editing the template we have installed to run the public website and even the special for kunena, but it was no template.css
Thank you
12 years 6 months ago #155902 by rich
Replied by rich on topic K 3.0.4: bordered tables
This is the wrong file. Go to "tempates/your Joomla! template/css/template.css" and add the code by 9themestore at the end this file.
Not [strike]administrator[/strike]/templates!
