Solved Problem Kunena 3 Joomla 3.2 ">" signs
12 years 1 month ago #154785
by Ickoski1
Problem Kunena 3 Joomla 3.2 ">" signs was created by Ickoski1
- cotswoldphoto
- Junior Member
- aka ClevaTreva
12 years 1 month ago #154787
by cotswoldphoto
There is always tomorrow. If there isn't, why worry? The world must be about to end!
Replied by cotswoldphoto on topic Problem Kunena 3 Joomla 3.2 ">" signs
It is because those elements are list items, and in a css file later than the Kunena ones your template has set that symbol has the default bullet point. I have found it easier in the Kunena admin area, Templates, Blue Eagle Template the last but one setting I set to Yes (Blend with Joomla Template), and then do my own thing inside my template css. But YMMV
12 years 1 month ago #154790
by Ickoski1
Replied by Ickoski1 on topic Problem Kunena 3 Joomla 3.2 ">" signs
And somebody else mayby have solution for this problem.
I searched and did not find in template.css why this sign schows up.
- 9themestore
- Premium Member
12 years 1 month ago #154791
by 9themestore
Replied by 9themestore on topic Problem Kunena 3 Joomla 3.2 ">" signs
Hi Ickoski1,
Please post your site url here if you site has been lived. That is fastest way to solve this problem.
Regards
Regards
12 years 1 month ago - 12 years 1 month ago #154792
by Ickoski1
Sory, this is the site:
www.pomorskiprzewodnikwedkarski.pl/forum/
Direck link to forum, everywhere you can see this > sign...
Last edit: 12 years 1 month ago by Ickoski1.
- 9themestore
- Premium Member
12 years 1 month ago #154795
by 9themestore
Open the template.css file in the current Joomla! template and add below CSS rules to the bottom of file.
After save reload your site to view changed.
Hope this helps
body #Kunena ul li:before,
body #Kunena ul li:after {
display: none;
Hope this helps
The following user(s) said Thank You: Ickoski1
Time to create page: 0.301 seconds
