This category is for discussing issues with the K 3.0 Blue Eagle template.
Question Text does not wrap (or table does not honor div sizing)
12 years 10 months ago #151778 by hjw
Hi all,
I have been strugling to get the messages displayed nicely. On mobile devices or small browser window the message text was cut off.
After inspecting the html objects I noticed the table width was bigger then the div object in witch it was contained.
After a long search I found the solution
in "Kunena.forum-min.css" find
#Kunena table{width:100%;border-collapse:collapse;padding:0;margin:0}
Add
table-layout: fixed;
I am not sure if it should be changed for every one. Let me know. If there is enough response I will try to change it in the template
Have fun!
12 years 10 months ago #151779 by 9themestore
Hi hjw,
I think it doesn't work. Please post your url site here, I will check and provide you a solution for this issue.
Regards,
12 years 10 months ago - 12 years 10 months ago #151788 by hjw
Hi 9themestore
It works.. for the messages :unsure:
Forum is only available for registered users, you can find it on www.ftdlotgenoten.nl/index.php/forum
Before: screenshot file
After: After file
But now I see the index of messages is a mess. I attached screenshot...
Thanks for willing to help
PS: I realized it is now for all tables.. I will try to add it to "table.kmsg" only
Last edit: 12 years 10 months ago by hjw. Reason: PS
12 years 10 months ago #151791 by 9themestore
Hi hjw,
Please send me a test account via email. I need an account to check your issue.
Regards,
12 years 10 months ago #151792 by hjw
I can't find your email. You can create your own account..
12 years 10 months ago #151795 by 9themestore
Please send me to [email protected],
The following user(s) said Thank You: hjw
