Solved AceSEF: top/bottom links not working as they should
The top link is to htfcfans.co.uk/#forumbottom
and the bottom link is to htfcfans.co.uk/#forumtop
I believe they are only picking up the base url and not the full (current) page url.
see attached
Also, is it possible to put the forum in any directory other than /forum/ ?
btw: On my previous posts in this forum I am not getting email notifications even though I tick the box to request them
In your case, the top link is <domain-name-root>/#forumbottom and the bottom link is <domain-name-root>/#forumbottom. The correct form (if you were using standard, ordinary, everyday, Joomla SEO) should be <domain-name-root>/<menu-item-alias>/<Kunena-category-alias>/<Kunena-forum-topic-alias>#forumbottom and similarly for the other one.
I think your issues are related to how you have enabled Search Engine Optimisation (SEO) on your site, involving the use AceSEF. If you look at the technical requirements specifications for K 2.0 (under the heading "interoperability with other Joomla extensions"), you will find that AceSEF is not, to our knowledge, compatible with K 2.0. This is probably a matter that you need to discuss with the developers of AceSEF. Can you try to disable AceSEF from your site to confirm if this is why link references are being re-directed in mysterious ways?
Unfortunately I do need something other than the stock SEF.
On your compatibility page nothing other than MijoSEF works and won't on the next update. MijoSEF didn't work in other ways for me.
Do you know if this AceSEF mod works? ... www.joomace.net/downloads/acesef/extensions/kunena-acesef
If not can you make any other suggestions?
Many thanks
We do not recommend any third-party SEO/SEF products for use with Kunena. Most of these other third-party SEO/SEF products add a significant overhead to your website and, as your forum continues to grow, eventually you will run out of PHP memory unless you are able to configure more memory for your website. Even if you think you have a sufficient quantity of PHP memory, you will eventually exhaust that memory and, over time, your site performance will degrade. Eventually your site will stop working.
Kunena is optimised to use standard Joomla SEO. If you want to know more about standard Joomla SEO, see Search Engine Optimisation (SEO) in the Wiki.
