Question JomSocial ActivityStream does not work
14 years 3 months ago #128318 by sternenprinz69
Hello ...
I just installed Kunena from version 2.0 to 2.0.1. Since I've installed JomSocial 2.6.1, I just see that after creating a Forum Post Activity Stream is not created even though the plugin is published.
Does anyone have a solution to make it work?
Thanks ever for your help.
Greeting sternenprinz
14 years 3 months ago #128614 by Matias
When exactly did it stop from working? Kunena upgrade, JomSocial?
14 years 3 months ago #128802 by sternenprinz69
So I can write and reply to threads, but none appears in JS Activity Stream.
The plugin "Kunena - JomSocial integration" is published and the settings are all set to "Yes" is set.
Do I do something wrong?
14 years 3 months ago #128855 by Matias
This could be because of the forum permissions. Activity stream will be only updated if category is either public to everyone or all registered members can see it.
That said, mapping between Joomla and JomSocial groups isn't perfect and there could be some bugs in it. So what are your category ACL settings?
14 years 3 months ago #128884 by sternenprinz69
The forum categories are open for all to write, but only registered users.
In the main pages JomSocial are public, but only registered users can actively participate.
14 years 3 months ago #128895 by Matias
Ok.. So let's try something. Go to Kunena category administration and edit one of the categories.
If the category was using user groups, change ACL to access levels. And vice versa. Then test if the activity stream starts working.
If it does, I have a bug to fix (but you also have your workaround).
