Question Posts visible only for registered users? J!2.5 + JS
I have a Kunena instalation with Jomsocial. When my users change there privicy options, the forum posts of these users are not showed to everyone. I need to change all Kunena posts to public access. How can I set it up?
_________________________________________________
The Best Brazilian Motorcycle Community
comunidade.motonline.com.br
My question was moved to: Forum > Kunena User Contributions and Third-Party Options > Extensions, Modules, and Plugins > JomSocial
probably nobody will want to read this post. I have no hope of answer.
I believe that moderation does not understand my question. I don't have any problem with Jomsocial, my problem is with the Kunena! Is the Kunena that it is not showing the posts for users not logged in! I need posts with public access! I do not know the solution to this problem is simple or complex, because I do not know what the solution.
The situation about this topic makes me woried about Kunena support. In my point of view is more simple and util provide an answer than move a topic.
Activity stream is also controlled by JomSocial and we cannot override settings in it.
With this situation, I decide to turn off the Joomla Cache. This problem was solved, but, now, I have a performance problem to solve.
The plugins could work, though if you just enable caching for 2-5 minutes.
However, Im thinking about APC or e-Accelerator to make PHP run faster.
