Question [hack] Related posts for 1.6
15 years 9 months ago - 15 years 9 months ago #85841 by guerilla
open view.php file and paste thiscode to bottom:
<!-- B: RELATIVE POSTS HACK BY GOLGE --><?php //similar posts hack by guerilla $percent=4; //similarity percentage, increase for sensitive matching. for example 10 is 10% match, 50 is 50% match, 100 is one o one $limit = 5; //set number of relative messages $query= "SELECT id, subject, name, time as zaman, catid, userid, MATCH(t1.subject) AGAINST ('$this->kunena_topic_title') AS oran FROM #__kunena_messages as t1 "; $query.= "WHERE MATCH(t1.subject) AGAINST('$this->kunena_topic_title') >= $percent AND id<> $this->thread "; $query.= "ORDER BY oran DESC LIMIT $limit;"; $sim_message = $this->db->setQuery($query); $sim_message = $this->db->loadObjectList(); echo mysql_error(); if (count($sim_message)> 0) { echo '<div class="kblock"><div class="kheader"><h2><span>Relative Posts</span></h2></div></div><div class= "klist-bottom"><table width="100%"><thead>'; echo '<tr><td><b>Subject</b></td><td><b>Author</b></td><td align="right"><b>Date</b></td><td align="right"><b>Similarity</b></td></tr>'; foreach ($sim_message as $sonuc) { echo '<tr><td><a href="index.php?option=com_kunena&Itemid='.$sonuc->id.'&func=view&catid=' . $sonuc->catid . '&id=' . $sonuc->id. '">' . $sonuc->subject . '</a></td>'; echo '<td>' . $sonuc->name . '</td>'; echo '<td align="right">' . CKunenaTimeformat::showDate($sonuc->zaman, 'config_post_dateformat') . '</td>'; echo '<td align="right">%' . (int)$sonuc->oran . '</td></tr>'; } echo "</table></div>"; } //similar posts hack by gerilla ?><!-- F: RELATIVE POSTS HACK BY GOLGE -->
run phpmyadmin and run theese codes:
ALTER TABLE jos_kunena_messages ADD FULLTEXT(subject) ALTER TABLE jos_kunena_messages_text ADD FULLTEXT(message)
you can change $limit=5 value to increase or decrease list count. to change match percentage you can change $percent=4 value to your own value.
Last edit: 15 years 9 months ago by sozzled. Reason: Changed subject to reflect better the issues
The following user(s) said Thank You: ChaosHead, tsetsoo
15 years 9 months ago #85856 by sozzled
Do you mean related posts? :unsure:
15 years 9 months ago #85857 by guerilla
sozzled wrote: Do you mean related posts? :unsure:
yes indeed :)
The following user(s) said Thank You: tsetsoo
15 years 9 months ago #85860 by sozzled
15 years 9 months ago #85877 by ChaosHead
Thanks, guerilla. But I had questions.
Many related posts are from that topic which is already displayed. How to eliminate them?
Or how to search for related topics, instead of related posts?
15 years 9 months ago #85881 by ariaji86
error when i run the sql.
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ALTER TABLE jos_kunena_messages_text ADD FULLTEXT(message)' at line 3
Thanks for all the hard works
