Question Disallowing links within messages
15 years 10 months ago #71248 by Ton87
Replied by Ton87 on topic How to disable linking
that is too bad, hacking core files is not really my best quality :p
15 years 10 months ago #71350 by Ton87
Isn't there a way to set blocking URLs from Joomla?
I could use a content blocker like Wordcensor to block http and www, but I only want it to affect the forum and not my entire Joomla based site.
15 years 10 months ago - 15 years 10 months ago #71558 by Mr Livered
Ton87 wrote: Good day,
I am looking for a way to disable all clickable links in posts on my Kunena board. So whenever somebody writes down an url or uses the code, I do not want it to be clickable so users need the copy-paste the adress into their adress bar.
Is there any possibility to set this with Kunena?
Regards, Ton
Hi Ton
Yes, I think we're trying to do pretty much the same thing. This is what I did in the end:
In kunena.parser.php, look for
$text = preg_replace ( '/(?<!S)((http(s?):\/\/)|(www\.[a-zA-Z0-9-_]+\.))+([a-zA-Z0-9\/*+-_?&;:%=.,#]+)/u', '<a href="http$3://$4$5" target="_blank" rel="nofollow">$4$5</a>', $text );
and replace it with:
text = preg_replace ( '/(?<!S)((http(s?):\/\/)|(www\.[a-zA-Z0-9-_]+\.))+([a-zA-Z0-9\/*+-_?&;:%=.,#]+)/u', '***please copy and paste: http$3://$4$5***', $text );
Edit: you'll also need to disable the parsing of the url bbcode as a link. I changed the relevant section of the parser file to:
case 'url' : $task->autolink_disable --; // www. > http://www. if (isset ( $tag->options ['default'] )) { $tempstr = $tag->options ['default']; if (substr ( $tempstr, 0, 4 ) == 'www.') { $tempstr = 'http://' . $tempstr; } $tns = "***link banned***"; $tne = ''; return TAGPARSER_RET_REPLACED;
Last edit: 15 years 10 months ago by Mr Livered. Reason: ps
14 years 7 months ago - 14 years 7 months ago #119766 by numerus
Is it possible to disable automatic transformation URL address into clickable URL links (in posts)?
I need to disable this function in posts in order to bring working mp3 player in Kunena.
I'm using latest Kunena 1.7.2 with default template on Joomla 2.5.
P.S. Excuse me, i posted this post into the wrong section. You can change it.
Last edit: 14 years 7 months ago by numerus.
14 years 7 months ago #119782 by sozzled
14 years 6 months ago #121185 by sunny33days
Hi, I have problems with spammers just posting links in my forum. I don't need clickable links. I am using Kunena 1.7.2 Is there a way I can "disable" clickable links or html? If there is a hack to do this, please let me know.
Please help, as this will really help me reduce spam links on my site.
Time to create page: 0.274 seconds
