Question [Resolved] Template buttons Problem (9themestore)
14 years 8 months ago - 14 years 8 months ago #116666 by sozzled
The border-radius CSS directive is not implemented in many versions of Internet Explorer: davidwalsh.name/css-rounded-corners
To help you better as far as the way that your smileys (emoticons) selection toolbar is concerned, it would be easier if you posted your configuration report. It would also help if you have a test account that we could use on your site to see the problem for ourselves. You can post your test account information using the "confidential" BBcode tag, like this:
[configuration]Username: Password[/configuration]
Last edit: 14 years 8 months ago by sozzled.
The topic has been locked.
14 years 8 months ago - 14 years 8 months ago #116675 by Angela1
thanks for replying.
I'm using IE7
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 200M
Joomla default template details : comaxium | author: Shape5.com | version: 1.0 | creationdate: October 2010
Kunena default template details : nts_kdark | author: 9ThemeStore | version: 1.7.0 | creationdate: 2011-05-07
Last edit: 14 years 8 months ago by Angela1.
14 years 8 months ago - 14 years 8 months ago #116678 by sozzled
I understand that you may have reasons for not wanting to show us where, specifically, you are having problems. That's OK but, if you have edited your configuration report, if you do not wish to share the full details of your site, it means that it will take us considerably longer to give you the help that you have asked for.
Unfortunately, as I don't know where (the URL of the affected website) the issue is, and have no means of seeing what can be done, there's not much that I can do to help. As you have also decided to keep to K 1.6.5 (which is not supported by the Kunena project team) there's not a lot we can do there, either. That's why the comments I've written here are general ones.
I would like to make a general point: You can do a lot with CSS; IE7 just makes things 10 times harder to do anything. Although K 1.6 is supposed to work with IE7, the K 1.6 project was actually delayed by 6 weeks while we tried to make things work at all with IE7. In the end we decided that we would probably never fully get K 1.6 to work with IE7. This is why, when K 1.7.0 was released, IE7 support for Kunena was withdrawn. I'm not saying that the problems can't be solved; I'm only giving you a few facts about why it will be difficult to solve in this particular case. Perhaps someone else may like to offer you some suggestions that will put things right.
Alternatively, if you decide to upgrade to K 1.7.1 you may find that things will work better for you.
14 years 8 months ago #116679 by Angela1
Sorry i only use 1.6 because 1.7 don't have translation in my language yet.
This solved the smiley issues:
#Kunena div#smilie {
background-color: #F0F4F7;
border-radius: 5px 5px 5px 5px;
padding-left: 17px;
width: auto;
height: auto;
overflow: auto;
on kunena.forum-min.css (it might help someone)
