Question How to use my own login module popup with K 1.7.1
14 years 4 months ago - 14 years 4 months ago #113735 by MAW_Trok
Hi to all, How can I fix this bug of Kunena?
I have installed the Story of Glory Template for joomla. This template have a script called "mootools.js" and it is located in "mywebsite/templates/storyofglory1.6/js/".
If I remove this script from the root "js" I can see the toolbar of kunena..., if I leave this script I can't see the toolbar.
There is a little problem, I MUST use this script for have the login popup, so Is there a fix for this?
Can someone help me to fix this?
I searched in the forum, but noone had fixed this problem.
I have CBuilder latest versione
Kunena Latest Version
Joomla 1.7
I read this guide, but no found answer to my problem: docs.kunena.org/index.php/Common_causes_...29_issues_and_Kunena
Last edit: 14 years 4 months ago by MAW_Trok.
14 years 4 months ago - 14 years 4 months ago #113738 by MAW_Trok
Replied by MAW_Trok on topic Re: Kunena 1.7 bug
if i remove this line in my template: <script type="text/javascript" src="templates/<?php echo $this->template ?>/js/mootools.js"></script>
I can see the toolbar, but the popup don't work.
14 years 4 months ago #113745 by MAW_Trok
I used the fantastic HOT LOGIN Plugin (dropdown login) and I removed this mootools.js!
Time to create page: 0.247 seconds
