Question Two problems
14 years 11 months ago - 14 years 11 months ago #113583 by agustin
Replied by agustin on topic Re: Two problems
ok, that did solve the problem. For some reason the "new thread" link still readirects me to another joombla template but with a wider text area.
I still couldn't solve the emoticons problem, you can see them but when you click on them, they do not appear in the text box. (even using kunenas default template)
Thank you for fixing the first problem
Last edit: 14 years 11 months ago by agustin.
The topic has been locked.
14 years 11 months ago #113586 by 810
Replied by 810 on topic Re: Two problems
I see that you use, jquery plugins. So try to disable mod_samilogin2 on kunena pages.
regards 810
14 years 11 months ago #113600 by agustin
Disabled mod_Sami Login JQuery Edition and the problem persisted
I'm going to keep investigating, if I solve it, I'm going to post the solution.
14 years 11 months ago #113601 by 810
try the jooomla default template.
regards 810
14 years 11 months ago - 14 years 11 months ago #113602 by agustin
ok, I tried disabling multiple things, I went back to the default template...still no luck
This is how it looks now:
[img
I didn't realize that the text editor is not appearing :pinch:
So that's probable caused by the same thing
I went to the html and I found this javascript plugins, modules & components
I could not identify in the backend some of them:
plugins/system/cdscriptegrator/libraries/jquery/js/jquery-1.4.4.min.js
plugins/system/cdscriptegrator/libraries/jquery/js/jquery-noconflict.js
plugins/system/mtupgrade/mootools.js
components/com_kunena/js/slimbox/slimbox-min.js
components/com_kunena/template/default/js/default-min.js
components/com_kunena/template/default/plugin/poll/js/kunena.poll-min.js
components/com_kunena/template/default/js/editor-min.js
media/system/js/validate.js
media/system/js/calendar.js
media/system/js/calendar-setup.js
plugins/system/qluetip/js/qluetip-1_1.js
mod_samilogin2/js/jquery.min.js
modules/mod_samilogin2/js/jquery-ui.min.js
modules/mod_samilogin2/js/side-bar.js
14 years 11 months ago #113603 by 810
ok, disable:
mod_samilogin2/
