Question Change "My Kunena Forum Posts"
- MikeMikeMike
15 years 3 months ago #98105
by MikeMikeMike
Change "My Kunena Forum Posts" was created by MikeMikeMike
On a user's profile in JomSocial there is a spot that shows "My Kunena Forum Posts". I would like to change this to say "My Forum Posts". Where can I edit this in the backend or is there a file I can modify? I checked the plugins but it does not let me rename it from there.
15 years 1 month ago #103869
by everett
Replied by everett on topic Re: Change "My Kunena Forum Posts"
I am trying to find out the same thing.
I have searched and read until my eyes hurt.
I am using Joomla 1.7, Kunena 1.6.5 and Jomsocial 2.2.4.
On my profile it says "My kunena updates" and I would like to change it to "My Forum Posts".
Well I guess we'll have to wait and see if anyone can help us with this.
15 years 1 month ago #103936
by qontrixz
Replied by qontrixz on topic Re: Change "My Kunena Forum Posts"
idk, but maybe you can change it in the database
15 years 1 month ago #103938
by mstephan
Replied by mstephan on topic Re: Change "My Kunena Forum Posts"
You would need to change the plugin name because JomSocial displays exactly what it sees. Without checking, I'm not sure if you can do this from the backend. If not, just edit the xml file to the name you want and clear plugin cache.
15 years 1 month ago - 15 years 1 month ago #104033
by Frunzik
Replied by Frunzik on topic Re: Change "My Kunena Forum Posts"
in mykunena.xml
translate it "PLG_MYKUNENA_FORUMPOST"
<name>PLG_MYKUNENA_FORUMPOST</name>
Last edit: 15 years 1 month ago by Frunzik.
- RedWatcher
15 years 2 weeks ago #107294
by RedWatcher
Replied by RedWatcher on topic Re: Change "My Kunena Forum Posts"
My mykunena.xml doesn't have PLG_MYKUNENA_FORUMPOST as a variable in the file. I do have this, which I think you are referring to:
<install version="1.5" type="plugin" group="community" method="upgrade">
<name>My Kunena Forum Posts</name>
<creationDate>2011-08-30</creationDate>
<author>Kunena Team</author>
<authorEmail>[email protected]
Removing "My Kunena" from the text above doesn't work. I looked for a plugin cache setting, and found the overall joomla cache settings, which I cleared and didn't help.
Time to create page: 0.213 seconds
