Question Strange Username display problem
15 years 5 months ago - 15 years 5 months ago #97639 by plix
Hello friends,
I am having a very strange issue. My Forum was working fine. After upgrading to K 1.6, everything works fine except when viewing a topic, the user name on top of the avatar, instead of displaying the actual User Name, it displays the following HTML code:
<a href=" www.mysitehere.com/username/ ">Username</a>
Please, how to fix this issue?
Many Thanks in advance.
Last edit: 15 years 5 months ago by plix.
15 years 5 months ago - 15 years 5 months ago #97658 by sozzled
When posting messages to the Support category, please read the posting guidelines printed at the top of the page.. Without seeing your K 1.6 configuration report, I am guessing that you have Community Builder installed. Am I right?
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago - 15 years 5 months ago #97662 by plix
Hello Soz,
Thanks for your quick reply. Yes, I have Community Builder installed. Sorry as i didn't include the Configuration report in my first post. Here we go:
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 2M
Joomla default template details : My template | author: MyTemplate | version: 1.0.1 | creationdate: 11/15/2008
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Third-party SEF components: sh404sef: Installed (Version : 2.2.6.973) | ARTIO JoomSEF: Disabled or not installed | AceSEF: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Enabled (Version : 1.6.2) | Kunena Login: Enabled (Version : 1.6.2)
Thanks!
15 years 5 months ago - 15 years 5 months ago #97666 by sozzled
Most importantly, K 1.6.3 is not supported. Upgrade to K 1.6.4 (see K 1.6.4 Upgrade Guide )
Upgrade to CB 1.4 (it's explained in the K 1.6.4 release notes )
Upgrade to J! 1.5.23 and disable "legacy mode" (this is explained in K 1.6 Technical Requirements )
Upgrade the Kunena add-ons to their latest versions.
15 years 5 months ago - 15 years 5 months ago #97669 by plix
Thanks again. Yes I am aware that I have to upgrade some Extensions, Mods etc in my Joomla. The problem is that I am so busy these days that I don't have enough time to get myself into upgrade processes right now. I will do it as soon as I find some time. What I was in need of in the mid-time was a quick fix to this Username display problem in Kunenan. Would you mind helping?
I think it shouldn't be a big issue and it shouldn't be a big deal for you developers and Support Techs.
Please help!
Many Thanks.
15 years 5 months ago #97672 by sozzled
It's your site and those are your issues to deal with as a priority for you to assess.
If you don't want to deal with these things yourself, you always have the option of paying someone to do them for you. Is that an option for you?
Time to create page: 0.146 seconds
