- Thank you received: 2
Important Cannot understand how to add signatures when using Community Builder
- Silencer2010
- Senior Member
i was very happy to see that there is Kunena 1.6.4.
But after I've upgraded (Version before - 1.6.3) my Sites, all Users who are not logged in will get an Error when they click on any Entry in the Forum.
That will happen:
Fatal Error was detected!
Please contact the site owner.
Go back
With Kunena 1.6.3 there were no Errors... When the Users are logged in, they can surf through the contents of the Forum without any Problem.
Is there a way to make a downgrade to 1.6.3?????
Hi Leute, seit dem Update von Kunena 1.6.3 auf 1.6.4 erhalten nicht eingeloggte Mitglieder ständig Fatal Error 500 wenn sie auf Beiträge im Forum klicken. Das passiert nicht, wenn man eingeloggt ist. Unter 1.6.3 gab es keine Probleme ...
Ist das bekannt ???? Was kann man tun???
Kann ich auf 1.6.3 wieder downgraden ???
- Silencer2010
- Senior Member
If I turn SEO off in Joomla and Kunena Users can surf through the Content of Forum.
But they can not open any polls... Then there will be the same error....
Please enable debug mode in both Kunena and Joomla! configuration panel to see waht's happen
- Silencer2010
- Senior Member
thank you for your Quick Answer.
With the Debug Mode I get the following:
Fatal Error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 491520 bytes) in modules/mod_cblogin/mod_cblogin.php on line 377
The error was detected in the Cblogin Module.
BUT: I have a few Websites and Forums on the same webhosting space. Only on one or two there is the error.
- Silencer2010
- Senior Member
Deactivate: CB (Community Builder) - Plugins -> Forum Integration (Kunena)
Then it works perfectly.. But on my other Sites it even works with that Option on... Is there any other way to write Signatures without the Option of the activate plugin?
