Question Need Help: Fresh Kunena installation looking for Community Builder table
15 years 1 month ago #92366 by kjspring
Installation is complete but I have having difficulty in enabling Kunena. I had a site with community builder but due to migration I had to remove most all of my components including community builder. I uninstalled Kunena then reinstalled without CB. Now when I create a menu link to the forum I get an error message during debug mode that tells me try it needs the table _comprofiler_plugin. This is a community builder plugin and I don't have community builder installed. Here is the complete error message:
500 - JDatabaseMySQL::query: 1146 - Table 'c6rage.jos_comprofiler_plugin' doesn't exist SQL=SELECT id, folder, element, published, type, params, CONCAT_WS('/',folder,element) AS lookup, name FROM jos_comprofiler_plugin WHERE published = 1 AND access <= 2 AND type = 'user' ORDER BY ordering
Another issue that seems is that I do not have any access to the configuration menu. All I get is a lot of links at the top to the other backend menu items. All the other items work except the configuration menu.
Has anyone had these issues before?
When I uninstall Kunena is it possible there are some tables that are not installed and the reason it is looking for this CB table?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : mangav3sfw | author: | version: 1.3 | creationdate: 2011-02-13
Third-party components: AlphaUserPoints: Installed (Version : 1.5.13) | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: The file doesn't exist uddeim.j15.xml !
15 years 1 month ago #92375 by 810
Please try kunena 1.6.3.
regards 810
15 years 1 month ago #92522 by kjspring
Nope, get the same issues with the configuration in the administration side. I tried to reinstall community builder and it got rid of that error but now I only get a white page when I try to go to the forum in the front side.
15 years 1 month ago #92574 by xillibit
15 years 1 month ago #92612 by kjspring
Dude you are a lifesaver, thanks. There was an issue with uddieim, and I got that fixed.
15 years 1 month ago #92668 by xillibit
Maybe, you can explain your issue and how you have fixed it to help others users
Time to create page: 0.277 seconds
