- Community Builder Integration -
- I have a "Display Name" field created and use that for the forums to pull the name. Didn't work well in 1.5 as well but now in 1.6.x works almost flawlessly.
- The user Display name is pulled correctly for the post however on the last post sections the real name is displayed not the proper display / nickname. Using the mapping functionality in the CBPlugin to make it happen but its not quite there.
- Login box only works if not viewing an actual thread. If I try to login while viewing a Thread it acts like its logging in then redirects back to the top of that Sections Topics. Then when I try to login it will log in correctly and we have to then navigate back to the correct thread.
- Have another thread asking about the profile not visible for guest message - but more explanation here.
- Have CB Profiles published publicly on a hidden menu. /hidden-profiles to meet CB Requirement of Profiles being public. However my visible menu item (another one) is registered users only. So the profiles are accessible but not sure why its getting this error on login. When logging in the user Would have access regardless so why the message after / during login?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 20M
Joomla default template details : rt_chromatophore_j15 | author: RocketTheme | version: 1.5.2 | creationdate: 03/29/08
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.2)
