Question Login and Edit issues
15 years 8 months ago #89673 by nyabynghi
Trying to log in to Kunena from the forum homepage redirects me to the homepage. So does the "Edit Profile" button once logged in. This may well be another SH404SEF issue but maybe the answer is already known here.
Thanks in advance
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 15M
Joomla default template details : js_relevant | author: Casey Lee | version: 1.0 | creationdate: 6/20/08
Third-party SEF components: sh404sef: Installed (Version : 2.2.3.945) | ARTIO JoomSEF: Disabled or not installed | AceSEF: Disabled or not installed
15 years 8 months ago #89678 by xillibit
Replied by xillibit on topic Re: Login and Edit issues
The only thing that i can advise you is to sue default joomla sef system instead of sh404sef
15 years 8 months ago - 15 years 8 months ago #89679 by nyabynghi
Replied by nyabynghi on topic Re: Login and Edit issues
Hmm, thanks. That will be a bit difficult because I have so many URLs already created by SH404SEF and indexed by search engines. I guess I could disable it for Kunena component alone as it works for everything else. They should put more effort in to get the components working better together, but it turns out they also have their own forum. Conspiracy theorist :) Thanks anyway. More suggestions welcome.
Last edit: 15 years 8 months ago by nyabynghi.
15 years 8 months ago #89787 by nyabynghi
xillibit wrote: Hello,
Continued to look into this and I wasn't aware you could do this for individual components. In the SH404 configuration >> by component tab >> under URL Processing I chose "skip" and under "use sh404 plug in if available" I selected the "use Joomla! router.php" option. Then purge URLs. Seems to fix most of the issues I was having.. including "Login" "Edit PRofile" and "User profile" all redirecting to the homepage.
I hope this is of use to someone else.
