- Thank you received: 24
Question Help needed with custom CB fields
15 years 9 months ago #86984
by Baze
Help needed with custom CB fields was created by Baze
Can anyone help me to display custom CB fields in user profile?
I need one simple text custom field to be shown under the users avatar (under the icons), i know that it can be done, but since i'm not a coder i can't do it myself. I can follow directions without any problem so all i need is directions
I'm using Kunena 1.6.3 and CB 1.4
15 years 9 months ago #86987
Replied by sozzled on topic Re: Help needed with custom CB fields
I haven't installed CB 1.4 on any of my websites yet and so I don't know what changes (if any) are involved in customising the cb.simpleboardtab plugin to achieve what you want to do. This category has a simple guide to customising the cb.simpleboardtab plugin in one of the sticky topics.
More "difficult" questions about customising this feature of Community Builder should really be directed, in the first instance, to the Joomlapolis support forum.
15 years 9 months ago #86989
by Baze
Replied by Baze on topic Re: Help needed with custom CB fields
Hi sozzled,
thanks for your reply, i've seen and tried the cb.simpleboardtab plugin before i posted the topic but i couldn't sort it out. I wanted a "custom" solution (and yes i know that unfortunately i'd have to do the modifications manually every time i update kunena).
There was a tutorial couple of years ago about the integration of jawards into the user profiles in fireboard, maybe that will help me... (just thinking out loudly)
cheers
p.s. Concerning the cb1.4 as much as i can see there are no changes in the cb.simpleboardtab plugin
cheers
15 years 9 months ago #86990
by Baze
OMG...can i take back everything i said?
I have switched cb.simpleboardtab sidebar mode to advanced, and put the html code with the fields code inside and voala, i got just what i wanted!
I'm terribly sorry i took your time Sozzled, the beer is on me next time
