Question Problem - CB 1.4 & Kunena 1.5.14
15 years 2 months ago #86900 by ProZak
after update Kunena from 1.5.13 to 1.5.14 and update CB to 1.4 integration is not working properly. From the forum integration is good, work well avatars and linking to the CB profile. However, in the Profile tab forum is empty. Show:
"This user has no forum posts.
No subscriptions found for you.
No favorites found for you."
Fields forumrank, forumposts and forumkarma are empty.
15 years 2 months ago #86915 by GoremanX
CB 1.4 added proper Kunena 1.6 integration, but I'm not sure if they retained Kunena 1.5 integration. You may also have to upgrade Kunena to get integration working properly again. Since this is a CB issue, your best bet is to ask the CB guys about this.
www.friendlyphotozone.com
15 years 2 months ago #86917 by ProZak
This looks like a problem with the forum. I installed CB first and everything was OK, and later upgraded the forum and the integration stopped working.
15 years 2 months ago #86919 by GoremanX
that's possible too, there have been some reported issues with Kunena 1.5.14. All I can tell you is that CB made some big changes, and everything works fine with Kunena 1.6.
15 years 2 months ago #87026 by ProZak
After update to Kunena 1.6 integration was working properly, but I had mootool's conflict. I was forced to return to an older version (1.5.14). Now:
- forum tab in CB - shows posts, but only the old ones, before downgrade. Forum tab doesn't show new posts,
- field forumposts - posts'es counter doesn't count new posts. Number of posts, which is shown, is before downgrade.
Time to create page: 0.228 seconds
