Question [Default Template problem] kwho and firefox
15 years 9 months ago #84177 by AnyWay
After upgrading to Kunena 1.6.3 I'm having a problem viewing the username over the user's avatar, a link is showed instead of the username (it seems caused by < and > html entities).
This seems to happen only with firefox, I have not this problem with Google Chrome and Internet explorer.
I'm using Kunena default template and Joomla 1.5.22.
Thanks for your help.
The following user(s) said Thank You: prophoto
15 years 9 months ago #84281 by prophoto
Same problem here...I have this problem in FF, Chrome and IE8.
15 years 9 months ago #84291 by tinetto
I had same issue. For me it was the Community Builder plugin.
I solved it by going in CB ---> plugin management ---> forum integration
in parameters select Sidebar Mode: basic
I hope it is the solution for you
bye
15 years 9 months ago #84477 by prophoto
This worked, thanks!
From the CB Forum:
I believe it's a known bug due to a change/bug in the kunena component. The issue and fix is here: forge.joomlapolis.com/issues/2205
If it's not too troubling for you I suggest waiting for CB 1.4 due to be released on Feb 14th.
