Question Wrong order of posts
15 years 11 months ago - 15 years 11 months ago #78354 by fourzero
Hello
I found that after upgrading to Kunena 1.6.1 I've lost control of posts' ordering. The order in a thread view is always DESC, no matter what is set up in user's profile.
I don't know if it is only my problem, as I've found here no thread about it.
Now I have found that in the file /components/com_kunena/funcs/view.php in line 308 there is a condition. It looks like:
if ($this->myprofile->ordering != '0') { $this->ordering = $this->myprofile->ordering == '1' ? 'DESC' : 'ASC'; } else { $this->ordering = $this->config->default_sort == 'asc' ? 'ASC' : 'DESC';
I changed the condtion to
if ($this->myprofile->ordering != NULL) {
and now it works fine.
Tested on Joomla 1.5.20 and 1.5.22
Last edit: 15 years 11 months ago by fourzero.
15 years 11 months ago #78381 by xillibit
Replied by xillibit on topic Re: Wrong order of posts
Do you using the default kunena template ?
15 years 11 months ago #78399 by fourzero
Replied by fourzero on topic Re: Wrong order of posts
Yes, I use only default template: www.genealodzy.czestochowa.pl/en/forum
What the code means in fact?
If my profile ordering is set to 0 (ascending) it omits this setting and gets the config->default_sort. It uses my ordering setting only if I have it set to 1 (desc). I get it always descending in result.
15 years 11 months ago #78412 by sozzled
Replied by sozzled on topic Re: Wrong order of posts
fourzero wrote:
I found that after upgrading to Kunena 1.6.1 I've lost control of posts' ordering. The order in a thread view is always DESC, no matter what is set up in user's profile. I don't know if it is only my problem, as I've found here no thread about it.
This is most unusual. I've not seen any other reports like this that affect users after they have upgraded to K 1.6.1. I tested this out myself and the preferred message ordering option works for me.
We are talking about the settings like I've shown in the following image, aren't we?
15 years 11 months ago #78449 by fourzero
Yes, there must be a clue. In my profile settings I have only two options:
- Last post first
- First post first
I have to look closer at the cb.simpleboardtab plugin (* @version $Id: cb.simpleboardtab.php 1324 2010-12-03 13:41:23Z beat $)
CB 1.3.1
15 years 11 months ago - 15 years 11 months ago #78525 by sozzled
So we're not discussing the Kunena user profile; we're discussing the Community Builder user profile, right?
Sounds to me that this is something that you need to discuss with the good folks at Joomlapolis .
Can anyone else confirm that they are experiencing the same issues with CB 1.3.1?
Last edit: 15 years 11 months ago by sozzled.
The following user(s) said Thank You: fourzero
