Kunena 7.0.8 Released
Question Sync avatars between Kunena 1.6 and Community builder
- windvanger
15 years 8 months ago #75228
by windvanger
Sync avatars between Kunena 1.6 and Community builder was created by windvanger
Is it possible to sync the avatars between Community Builder and Kunena 1.6? I like the new look of the profile of Kunena, but when I select Kunena in the dropdown list from the configuration page -> integration the avatars are gone.
15 years 8 months ago #75253
Replied by sozzled on topic Re: Sync avatars between Kunena 1.6 and Community builder
There's no "synching" of avatars between Kunena and Community Builder. You either use CB avatars or you use Kunena avatars.
Forum Configuration » Integration » Avatars = Community Builder
- windvanger
15 years 8 months ago #75372
by windvanger
Replied by windvanger on topic Re: Sync avatars between Kunena 1.6 and Community builder
Thank you for the answer. I was wondering this because it is not possible to change the CB avatar when you use Kunena for viewing and editing the profile. I want to use Kunena instead but then all the avatar pictures are gone.
15 years 8 months ago #75375
There are other ways of changing the CB avatar. You just have to give your users another way. Community Builder provides you the tools to allow users to change their avatar image. If you want you users to use the Kunena user profile, then keep the profile integration set to "Kunena" and the avatar integration set to "Community Builder". It's up to you how you inform your users how to use your website.
Where I use CB on my sites, I have a user menu item that allows my users to go to the Community Builder page where they can modify their avatar image (if they want) and do the other CB things. When my users access the forum, they get the CB avatar but they use the Kunena user profile. I find that the Kunena user profile is better for users when they use Kunena. CB is used for other things. This is just my opinion, of course.
The following user(s) said Thank You: windvanger
- windvanger
15 years 8 months ago #75420
by windvanger
I tried this before, but I don't like the CB profilepage so much. But I will add this because I want to give the visitors the possibility to change there avatar. Some changing to do. Thanks again.
15 years 8 months ago - 15 years 8 months ago #75423
It simple. Give you users a menu option to allow them to use CB update their avatar. Set Kunena to use Kunena user profiles but use CB avatars.
Give your user CB outside the forum; don't give your users CB inside the forum. Two seconds work. Do you understand?
Time to create page: 0.276 seconds
