Question Kunena forum plugin for JomSocial
15 years 11 months ago #48203
by cheetooh
Kunena forum plugin for JomSocial was created by cheetooh
I noticed this Kunena forum is using "Kunena forum plugin for JomSocial". May I know where to get this plugin?
Please help. Thanks
Please help. Thanks
15 years 11 months ago - 15 years 11 months ago #48206
by @quila
Replied by @quila on topic Re: Kunena forum plugin for JomSocial
this is only plugin we are using with jomsocial
joomlacode.org/gf/project/kunena/frs/?ac...&frs_package_id=5011
and you need to activate JomSocial integration in the Kunena Configuration.
Last edit: 15 years 11 months ago by @quila.
15 years 11 months ago #48208
by cheetooh
Replied by cheetooh on topic Re: Kunena forum plugin for JomSocial
Thanks for your reply.
But the download is for "Kunena menu plugin for JomSocial" (mykunenatoolbar). It is different from "Kunena forum plugin for JomSocial".
You will be able to see it when you go to your "My Applications" under this Kunena forum profile.
Thanks once again
Thanks once again
15 years 11 months ago #48209
by @quila
When you activate Jomsocial Integration and enable Activity stream in the Kunena Configuration, do you see the same on your site in "My Aplication" menu ?
15 years 11 months ago #48211
by cheetooh
Solved. Thanks for your help!
15 years 11 months ago #48721
by chela5808
Replied by chela5808 on topic Re: Kunena forum plugin for JomSocial
Hello, I downloaded the plugin, enabled it and set to core, then, my web site goes completeley blank.
Can you please help?
Here is my installation info:
Kunena:
Installed version: Kunena 1.5.11 | 2010-04-04 | 1884 [ Kirjeldama ] | Copyright: © 2008-2009 Kunena | License: GNU GPL
Jomsocial:
Version: 1.6.290
JS G Kunena:
Version: 2.2
Kunena:
Jomsocial:
Version: 1.6.290
JS G Kunena:
Version: 2.2
Time to create page: 0.236 seconds
