Question JomSocial Integration with Kunena as a replacement for Group Discussions
- the_target
14 years 8 months ago #117794
by the_target
I am considering Kunena to provide a richer sharing environment for the trading members of our site. Specifically, we need a better way to share and discuss chart setups and be able to reply with images and videos. It appears that Kunena supports this, per the example chart attached.
Anyone had success with this integration or is it riddled with complexities?
- Jiminimonka
- Elite Member
- YBAS!
14 years 8 months ago #117819
by Jiminimonka
Replied by Jiminimonka on topic Re: JomSocial Integration with Kunena as a replacement for Group Discussions
No it is not difficult to integrate the two together, this website used Jomsocial - see People menu.
The following user(s) said Thank You: the_target
- the_target
14 years 7 months ago #118862
by the_target
Replied by the_target on topic Re: JomSocial Integration with Kunena as a replacement for Group Discussions
Got it all working well. Just have to figure out getting forum activity to show up in the JomSocial Activity stream.
- Jiminimonka
- Elite Member
- YBAS!
14 years 7 months ago #118865
by Jiminimonka
I am also having that issue, it was working then it stopped. I have not bothered looking into it yet though.
- the_target
14 years 7 months ago #118893
by the_target
I got it working on my J2.5, JomSocial most current, and Kunena 1.7.2
I had to change the access type in the Category Manger for each category item to use User Groups instead of Access Level. After configuring each item, it worked perfectly.
- Jiminimonka
- Elite Member
- YBAS!
14 years 7 months ago #118913
by Jiminimonka
I think that setting Access Levels is the way to do it in J2.5 and User Groups is how it should be done in J1.5, so maybe this is something that needs addressing in future updates.
Time to create page: 0.247 seconds
