Question AlphaUserPoints not giving points for posts in private forums
14 years 10 months ago #115366 by Paladin Brewer
Hello there,
I posted this problem on the AUP forum weeks ago but it seems pretty quiet over there, so I thought I would try here. I am using Kunena 1.7, Joomla 1.5.24 and Alpha User Points. All the point rules work fine. My problem is that if people make posts on forums that are only for certain user groups, they do not get awarded points. Only in the public forums. How can I fix this issue? I am also using ArtOf User for my usergroups.
14 years 10 months ago #115637 by Paladin Brewer
Anyone? :/ Is this something really easy Im missing or what?
14 years 10 months ago #115640 by Paladin Brewer
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : rt_dominion_j15 | author: RocketTheme | version: 1.5.13 | creationdate: October 21, 2011
Kunena default template details : nts_kdark | author: 9ThemeStore | version: 1.7.0 | creationdate: 2011-05-07
Third-party components: AlphaUserPoints 1.5.13 | CommunityBuilder 1.7.1 | UddeIm 2.5
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.7.0
Modules: Kunena Latest 1.7.0 | Kunena Stats 1.7.0 | Kunena Search 1.7.0
14 years 10 months ago #115643 by sozzled
14 years 10 months ago - 14 years 10 months ago #115735 by Paladin Brewer
Alright....I upgraded to 1.7.1 and the problem is the same.
I read it may have something to do with something getting removed because it was showing active topics in peoples profiles, but I dont use AUP Profiles, I use CBs so that doesnt matter to me.
Last edit: 14 years 10 months ago by Paladin Brewer.
14 years 10 months ago #115737 by sozzled
From your last configuration report, you seem to have a number of menu items (some of them may have conflicting aliases). There were also a number of add-ons that you were using designed for K 1.7.0 (these need to be upgraded, too).
Try setting Kunena configuration options back to original, default values.
I don't know anything about AlphaUserPoints or how to give points for posts. Maybe someone else knows why you are having problems. I'm only trying to advise you that you need to get a reliable basis, first, before working out why you are having problems with AUP (which I know nothing about).
Time to create page: 0.150 seconds
