Question [SOLVED] Why Kunena_msg_1 doesn't show the same content?
15 years 2 weeks ago - 15 years 2 weeks ago #110983 by iLucato
Hi folks, I'm trying to add SexyBookamrks into Kunena_msg_1 position, and to achieve that I'm using a Joomla plug-in and one module:
- SexyBookmarks (plug-in)
- Article as Module (module)
Ok, by using the command {SexyBookmarks} into any article it shows the bookmarkers icons in the article as expected, but when positioning the article into the Kunena_msg_1 position, it just shows the command {SexyBookmarks} instead of the icon as into the articles.
Any idea what could be wrong or what can I do to it show the article as it is?
Is there any way to place {SexyBookmarks} into Kunena_msg_1 position without using the module "Article as a module"?
Thanks in advance.
Last edit: 15 years 2 weeks ago by iLucato.
15 years 2 weeks ago #110999 by Matias
For some reason content plugins do not get loaded when you're using our module position. Which Joomla version are you using?
15 years 2 weeks ago #111001 by iLucato
Matias wrote: For some reason content plugins do not get loaded when you're using our module position. Which Joomla version are you using?
Hi Matias, I'm still using 1.5.22 (once I didn't get yet to move to upgtade to J1.7 with Jupgrade to upgrage Kunena together).
Well, I just got to make it work. I mean, not with the SexyBookmarks+Article as a module, I just found single module for bookmarks called "IPT social button" and it works within these Kunena position. ;0)
