Question JM Experts Login Register module and K 1.6
14 years 9 months ago - 14 years 9 months ago #102126 by orsouser
Good day! I had a problem with Kunena on my site. I installed the forum ver. 1.6.4 on Joomla! ver. 1.6.5. The forum worked except one thing. I couldn't save any changes in my profile. And it was because the button 'Save' didn't work. It was nothing when I pushed the button. I tried to synchronize users, but it didn't help: I couldn't save any changes in the profile. Then I switched on the standard registration module (I had mod_loginregister 1.5.6aJ1.6 before on my site). And finally it started working. Now I can save any changes. So, the question is can it be the problem just in the registration module (mod_loginregister) or is it a problem in Kunena and the forum cannot support any other registration module except a standard one? Thank's in advance.
This is my configuration report
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 64M
Joomla default template details : digitalwarehousetemplate | author: FreelanceUnity | version: 1.0 | creationdate: 2011-07-22
Kunena default template details : Darky Green 1.6 | author: gonzaunit | version: 1.6.0 | creationdate: 2010-10-25
Last edit: 14 years 9 months ago by orsouser.
14 years 9 months ago - 14 years 9 months ago #102179 by sozzled
G'day, orsouser, and welcome to Kunena.
Please read What information should I include when I ask for help (including how to post my configuration report)?
Please do not edit that report. There are certain details in that report that you have removed. Please don't remove any of that information.
Is this something that comes standard with J! 1.6 or is this a Joomla extension?
Last edit: 14 years 9 months ago by sozzled.
14 years 9 months ago #102202 by orsouser
sozzled wrote: G'day, orsouser, and welcome to Kunena.
Thank you!
sozzled wrote: Please read What information should I include when I ask for help (including how to post my configuration report)?
I'm sorry, I thought that I shouldn't post all the information.
sozzled wrote: Is this something that comes standard with J! 1.6 or is this a Joomla extension?
mod_loginregister is an extension for Joomla! I used this instead of standard registration.
This is my configuration report:
14 years 9 months ago #102212 by xillibit
You have maybe a javascript conflict somewhere, please check in firebug if you see javascript errors.
14 years 9 months ago #102225 by orsouser
Yeah, I checked and FireBug found 1 error
go is not defined
edit() edit (line 93)
jQuery.noConflict(go); edit (line 93)
nothing else was found.
14 years 9 months ago #102272 by sozzled
I downloaded the Login Register module from JM Experts and installed it on a fully-working test site build on J! 1.7. This module does not work with K 1.6.x (well, it does, in part, but you have to know where to look to find the bits that break) and disables the profile Save button.
Simple solution: do not publish the Login Register module on any Kunena pages on your site.
The following user(s) said Thank You: orsouser
Time to create page: 0.273 seconds
