Question Manual language installation
Is it possible to download the German language files for Kunena, and manually install them to the language folder, for Kunena to recognise this as an alternative language?
What exact kunena and Joomla version are-you using ?
In kunena archive, you will find some language package and you can install it with Joomla extension manager. It's not Kunena which recognize language but Joomla! himself
From my research of the forums, I was under the impression that Kunena comes with multiple language support, and will install the languages that it finds in the Joomla installation. Obviously got that wrong.
What do you mean by the 'kunena archive'? Is this the download file? I've looked there and cannot find any language files. I've also searched this site for language files.
My Joomla is installed with front-end support for both English and German. After I install Kunena, I can see the Kunena component language files in the en-GB language folder, but the equivalent files do not appear in the de-DE folder. I'm assuming that this is the root cause of my problem, and the solution is to install them there.
You are right, if you have the main language definie for Joomla! to german, the german files will be isntalled..sech wrote: Thanks for the response. I'm using J 1.5.23 and K 1.6.4.
Look closely, in the kunena archive that you had downloaded here, look in archive directory.
