Question Polish translation Kunena 1.6
15 years 6 months ago #88796
by svanschu
Kunena Contributor & Language Coordinator
Kunena Birthday Module | Kunena LaTeX Plugin | SchuWeb Sitemap with free Kunena Plugin
Always up to date with Twitter
Replied by svanschu on topic Aw: Re: Polish translation Kunena 1.6
Your are missing double quotes " " in your files, see original en-GB files how to do it. Without them they won't work in Joomla 1.6 …
Also adding standard heading would be nice …
15 years 6 months ago #88804
by Randal
Replied by Randal on topic Re: Aw: Re: Polish translation Kunena 1.6
Ok, I added quotes and change XML files.
But it not working right in 1.6. Can you tell me why? And what exactly do you mean by heading? Heading in ini files, or description in XML?
15 years 6 months ago #88806
by svanschu
Replied by svanschu on topic Aw: Re: Aw: Re: Polish translation Kunena 1.6
the heading in ini file. This 3 lines with ID: and so …
What does not work exactly not work in J1.6? The install or the use?
15 years 6 months ago - 15 years 6 months ago #88809
by svanschu
Replied by svanschu on topic Aw: Polish translation Kunena 1.6
LOL you have two " " at the end of your .ini files --> invalid file
and in .menu.ini you don't have to use " bcause this file is only for Joomla 1.5 …
Last edit: 15 years 6 months ago by svanschu.
15 years 6 months ago #88810
by Randal
Replied by Randal on topic Re: Aw: Re: Aw: Re: Polish translation Kunena 1.6
I don't know exactly. Install proces in 1.6 don't gave me any error. But only menu items are translated in 1.6. In 1.5 everything is allright.
PS!
Kunena.org give send to me notification in wrong language:
Neue Antwort in Kunena
Betreff : Aw: Re: Aw: Re: Polish translation Kunena 1.6
Kategorie : Translations
Geschrieben von : LDA
URL : www.kunena.org/forum/107-translations/56...it=10&start=10#88806
Nachricht :
Dieses Abonnement kann beendet werden, indem du im Forum das Thema besuchst und entweder oben oder unten, auf den Button „ABO BEENDEN“ klickst
Bitte nicht auf diese E-Mail antworten, es ist eine generierte Mail.
PS!
Nachricht :
15 years 6 months ago - 15 years 6 months ago #88811
by svanschu
Replied by svanschu on topic Aw: Re: Aw: Re: Aw: Re: Polish translation Kunena 1.6
Yes that's an known issue …
Joomla 1.6 is very strict … in Joomla 1.5 you can nearly do what you want and it works …
