Question Language files for 1.6
16 years 4 months ago #51274 by svanschu
To make it easier for the translators, I want to show you in this post the changes we make in the language files. So you only have to add/modify/remove the specific strings.
If you find some strings in Kunena which can not be translated please tell us so we can change that. Or if a string need a variable, because the word order is in your language different.
This Thread will only carry the changes in the ini files. Discussions please in the Kunena 1.6 specific forumcategories.
16 years 4 months ago #51275 by svanschu
Replied by svanschu on topic Language files for 1.6
Not yet implemented in trunk but will be later
backend --> kunena.install.ini
COM_KUNENA_INSTALL_DELETE_STATUS_FAIL
COM_KUNENA_INSTALL_RENAMING_FAIL
COM_KUNENA_INSTALL_INCLUDE_STATUS
16 years 4 months ago - 16 years 4 months ago #51393 by svanschu
Adding:
backend -> Forumconfig -> Plugin tab
COM_KUNENA_THANKSSTATS="Aktiviere Dankeschön Statistik"
COM_KUNENA_THANKSSTATSDESC="Aktiviere Dankeschön Statistik"
COM_KUNENA_THANKSPOP="Anzahl Top Dankeschön Beiträge"
Last edit: 16 years 4 months ago by svanschu.
