Question Croatian transation with croatian icons, Kunena 1.5.8.
16 years 3 months ago - 16 years 3 months ago #37000 by marko123
I have Croatian translation with a Croatian icons for kunena forum 1.5.8. In front-end juser is translated all, bt in back-end user not all. Same small text.
Imam prijevod na Hrvatski kao iikone na hrvatskom za Kunena 1.5.8. Front-end prevedeno je sve, ali za back-end nisu provedeni samo neki mali dijelici, npr, ono sastrane pokraj odabira u konfoguraciji kumene.
Icons:
Mark forum read => Označi forum pročitanim
Subscribe => Pretplati se
Ikons like this only!
Last edit: 16 years 3 months ago by marko123.
16 years 3 months ago #37335 by Sil
Could you please post translation with icons included? Thanks.
16 years 3 months ago - 16 years 3 months ago #37395 by marko123
sorry guys
the language file are here,
and icons, but only icon like mark forum read, replay, reply topic but on croatian
thx
File Attachment:
File Name: Croatian_t...na_1.zip
File Size:94.56 KB
16 years 3 months ago #37412 by sikvdila
can you post a little tutorial how start kuena translation?
Hello form Georgia :)
16 years 3 months ago - 16 years 3 months ago #37449 by marko123
ok, if your user uses the site as Croatian, then the kunena show in Croatian. What is needed is where to put kunena directory:
../administrator/components/com_kunena/language ,
or if you are using subdomenenu it's folder:
../your_subdomain/administrator/components/com_kunena/language.
As far as the icon, I had to use the site for the Croatian language and I was not required to have and English, though, and I made which was not a problem
in default_ex / images directory I put the Croatian directory, in which I copied all the files from the English folder, and default_ex / images / Croatian / icons deleted icons that were in English and put the icons that I edited in Croatian.
for English or Croatian forum, I have not had any problems
16 years 3 months ago #37521 by sikvdila
thanks for reply
and I have one question, how change kuena board language? when I translate it
Time to create page: 0.225 seconds
